name this connector
While I was under the hood looking for trouble tonight, I find this connector coming out of a wiring trunk on the drivers side engine area.
I have no idea what it is or what it's suppposed to connect to-there's nothing in the area that I can find that's missing a wire. Any idea? It's a '97 Blazer LS, 4.3 2wd. http://img.photobucket.com/albums/v2...r/IMG_1181.jpg |
Re: name this connector
Yea, I have a connector loose like that on my 1995 too.
I honestly don't know what it is for though. I think it is meant to be unattached.
1995 Factory Blazer Service Manual for sale, PM if interested. |
That's a test connector for certain testing modules. Basically it's 12 volt constant power.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
It looks like the fuel pump test wire.
Connect to 12 volts to test fuel pump so you don't have to go turn the Key when checking fuel pressure. |
Re: Re: name this connector
Mine's a 1995. It must have been moved it for 1996 & up.
Can you put a Voltmeter on it to see if it's 12 ? The fuel pump wire is on driver side on 1995. I jumper it to 12V and the fuel pump runs. |
You can put 12 volts on fuel pump test wire and fuel pump run but that is not it's purpose. The wire is 1-Check to see if power is going to pump, 2- to use low amps probe and scope to check pump. If there is power on wire then pump should have power and work. If power and no fuel bad pump. And yea you will only have power ofr few seconds when key is turn on and only while cranking or the engine running.
Curiousity killed the cat , and does wonders for starting wars on forums . It looks like a power wire for some kind of test probably something a dealer mechanic would connect to it and charge you out the yingyang for with a special connectivity rate by the minute .
OH look , mine has it too , but its on the firewall above the wiper motor . They change it for every year . Just to keep us on our toes. It may be something relating to the antikock brake system since it is near it . OR if you have an airbag , be carefull what you probe.
The fuel pump test wire will be tan or white... Again, that's a power wire for test equipment... A while back I asked the dealer the same question... Since it really never gets used, it now powers my fog light relay..
Re: Re: Re: name this connector
hahaha, I actually was going to ask the same question this weekend. I have the same thing on my 96. There seem to be maybe 5 of these red wires, but this one is not attached to anything! What kind of amp load do you think it could handle?
Re: Re: Re: Re: name this connector
And on my '98, it is not a two 2 prong. Mine is a single prong, and it grounds through the body of the hood. In fact, all cars I've ever seen with underhood lights ground through the hood, making it a single prong connector. |
I was wondering if it is a 12v constant then can someone hook up a light source to it.. like the Chevy Silverado's under the hood.. the retractable flash light type deal. I had one on my old silverado and wouldn't mind one on my blazer.. If it is the same for a 4X4 1999 Blazer
