Old 04-24-2005, 08:29 PM
KPot2004 KPot2004 is offline
vortec heads, older style block
how hard is it to get vortec heads (l31) to work on an 87 and earlier block???, i am thinking about building a sleeper 305 with the exact same parts in this list, 325 hp isnt bad for a 305
http://www.goingfaster.com/spo/325_h...chevrolet.html
thanks in andvance
Old 04-24-2005, 08:49 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
well that site that u linked told u exactly what u would need to put it on an '87 or earlier block, u would need self aligning rocker arms and some center bolt valve covers... other than that u need a different intake manifold but other than that it should be straight forward... good luck w/ ur 305, i like to see guys doing something different
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 04-24-2005, 09:03 PM
Re: vortec heads, older style block
yeah i saw that but they were not very specific, i looked on jegs and i cant find self aligning rockers, i knew i needed the valve covers but i looked and i cant find the rockres anywhere, how much would they be??
Old 04-24-2005, 11:11 PM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
for my reg. centerbolt heads on my 350, i found proform roller rockers from jegs 1.6 ratio, for 198.88, those are self aligning... i think for the vortec heads there either those, or they run about 298.99
