I want to get exhaust for my car.. ( better ).. Im thinking 2.5" y-pipes and 3" tips. BUT im not too sure that would sound the best and get the most performance out of it.
Also, I justs wanted to know if it was possible for a tru dual exhaust from the header to muffler, because the mechanic I went to said i cant do it. I also know i need a new cat, any advice would be most appreciated. Thanks.
1993 v6 3.4L |
Re: Exhaust Suggestions..
Its a V6 right (judging by the lack of Z28 emblems) if so then go with RkSport headers, high flow cat and Magnaflow catback. I have also heard it is not possible to get true dual exhaust on the 6's. As for suggestion on cat I got a Catco high flow ($130 summitracing.com) and it does feel a little bit quicker but with a full exhaust it will help even more. Oh and check out http://www.camarov6.com/ubb/ultimate...;f=25;t=006640 it has a bunch of diffrent exhuast setups with soundclips
White 07 STI, Bone stock for now |
It is possible to do true dual exhaust on f-bodys but it's not really feasable. It is a pain in the butt to do true dual and it will hang down super low so the pipes may hit the ground sometimes, like over speedbumps. Plus, on a six cylinder dual exhaust isn't necessary.
Also if you are looking for good sound look into Magnaflow mufflers I hear they cound great on the 3.8's. As far as the cat goes I have a Catco universal cat sitting here that I will sell you pretty cheap. It's not a hi-flow but it is a 2.5 in 2.5 out. Send me a PM if you're interested.
1994 3.4L Chevrolet Camaro - No more 2006 Hyundai Sonata |
Im probally going to go with the catco hi-flow and 2.5 magna flow muffler. Thanks for the help guys.
1993 v6 3.4L |
Go Magnaflow 3" LT1 catback... also a lot of 3.8 and 3.4 guys have problems with catco cats throwing SES lights, much less people have problems with Carsound (magnaflow) cats, I havent had a prob with mine.
You can get a true dual, but it would be expensive, a hassle, give you almost no ground clearance, and would probably be overkill on the v6. if you want to check it out tho, I know texas speed makes a true dual kit.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
my fbody has true dual exhaust. the left side crosses over lile stock and both pipes run under the right side but cross over the axle so the right side comes out the left rear so both pipes are about the same length
what would my camaro sound like with a cherry bomb glass pack on it, until i can get the $$ again to put a good 3" exhaust system. spent all my $$ on payin car off, well mostly... but was thinking of runnin cherry bomb or other glasspack would it sound good, and if anygood, what size of inlet/outlet would i need, i believe its still stock exhaust so does anyone know the size of the stock pipes?
Re: Re: Exhaust Suggestions..
I agree.....Magnaflow.
BTW...I am going to running Magnaflow mufflers on my duals.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Now that would sound sweet...
91 RS Camaro V8 305 TBI cold/ram 14"/3" open element K/N filter 3.73's B&M Megashifter 180 thermostat Flowtech TERMINATOR Exhaust 3" exhaust cutout Silvania Silverstar Headlights Ronal R15 Firehawk Wheels Hankook Ventus Sport (front) Sumitomo HTR+ (rear) 275/40ZR 17 all around... _____________________________ |
i jus tgot done putting on a spintech exhaust last night for my friend, hes got hedman headers with a y-pipe that goes to stock location b4 the cat on his 83 Z. we took a spintech racing muffler its like a tiny 8X4 (roughly) box, and welded it to the y-pipe, and put a turndown pointed to the back. ground clearance is not an issue, and its loud, and sounds sick. very streetable. i myself have a dump out the side no muffler, sounds good as well. all in ur preferance
I had an idea that Ive been thinking about for dual exhast for a 3rd gen, please tell me if im crazy or right on.
Take a 3" exhast pipe (or 2.5" whatever you want) and oval it, run it along the frame rails as much as you can, and run your duals that way.
