Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 04-24-2005, 01:54 PM
Mayday0017 Mayday0017 is offline
Post Compresion numbers
I did a compression test like a week ago and it was 150,150,150,150 being even all across is good but are these numbers low, normal, (pretty sure not high) I'm just not sure. I was thinking 170 was factory for some reason I think I'm getting blow by but I don't know. Others please post compression Numbers
Old 04-24-2005, 04:20 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Post Compresion numbers
leakdown will tell you more than a compression...
im doing
1) 95+%
2) 90+%
3) 95+%
4) 95+%
Fuck the SR20 intake manifold
Old 04-24-2005, 04:21 PM
R.W.240's Avatar
Banned
PS 150+ is excelent for any 15yr old motor.
Old 04-24-2005, 04:29 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Not an SR, lol, but still.
1- 182psi
2- 182psi
3- 182psi
4- 180psi
R.W. is correct. I'm gonna pick one up sometime. You can actually use the hose off your compression tester and just pressurize the cylinder via air compressor and listen for air leaking past. Very helpful finding headgasket leaks.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 04-24-2005, 06:32 PM
D-Bo's Avatar
D-Bo D-Bo is offline
mayday, it might have been the tool you were using that gave you lower than usual numbers. the chances of all four cylinders in a 4 year old engine being consistently 10% lower than what is considered normal seems like quite the coincidence
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 04-26-2005, 02:17 PM
winstonusmc's Avatar
winstonusmc winstonusmc is offline
the FSM states the compression should be 128-156psi with 14psi difference between each. This is straight out of the S14 FSM, an english S13 SR20DET FSM doesnt exsist. My numbers are about 145 for all.
SR20DET RPS13
3" Trust Downpipe, Catco Cat, RS*R ExmagII Catback
Z32 Brakes, Tomei Technical Traxx LSD
Blitz BOV
Old 04-28-2005, 12:36 PM
twitch24 twitch24 is offline
then, my #'s are way off for a 1991 DOCH at 170 across the board? and leakage it almost next to nothing with 111675 on my motor and the rest of my car
Old 04-28-2005, 02:19 PM
The KA has much higher numbers because of higher compression. my numbers were for the SR
SR20DET RPS13
Blitz BOV
Old 04-28-2005, 03:40 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
im pretty sure KA is
Im pretty sure KA is 179-152 with 14 PSI difference MAX...ill go check one sec...OK If someone can find me a Manual for the 240SX that has only the 240SX in it i will buy it off them with interest!!...my manual is for Stanza/200SX/Pulsar/Sentra(i think) So there are over 12 different ENGINES in there not to mention the Stanza also comes in 4WD so nice diagrams on Transfer cases when your trying to find the KA24 Trans...
Old 04-28-2005, 05:28 PM
240SX Guy
Uh, www.zeroyon.com has downloadable FSM for pretty much all the 240sx versions. Except the redtop silvia as I don't think there is a manual avaliable in english for that car.
-Cory
12.6@122mph
Old 04-28-2005, 07:06 PM
monooxide's Avatar
Banned
no...
I want the actual Physical Manual
