Old 04-06-2002, 07:00 PM
brian0724 brian0724 is offline
Angry help me I miss my 'Stang
I need help with my 89 mustang lx 2.3l
Here is my problem. When I start the car the oil pressure shoots up to normal and the engine runs beautifully. But, as soon as the car warms up the oil pressure drops like a stone to nothing and the engine runs like its full of rocks. If anybody has any idea what is causing this I would love some advice. I am completely stumped. As well as replying to this e-mails can be sent to [email protected].
Help me please I miss my stang.
Old 04-07-2002, 06:38 PM
milktasd2000 milktasd2000 is offline
Thumbs up uhh
Check your dipstick. Are you running enough oil?Put some slick 50 and some new oil, if it still does it ask an actual mechanic or ask here:
The speedtrap
They have the answers to everything.
1996 Cobra Laser Red
3.73
Underdrives
Subframe Connectors
Sequential Taillights
BBK Longtube Headers
BBK Offroad Hpipe
Delta 40s
Tint
WMS Cold air Induction with 87mm Mass air
http://www.milktasd2000.com
Old 04-09-2002, 07:28 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Your oil pickup sounds like its getting clogged, drop your oil pan and make sure its clean. Other than that it sounds like your oil pump is going out, but check the screen first.
I have seen this happen on cars with a lot miles, the valve have these rubber sleeves that over time get hard and break up that will eventually make there way down to the oil pump and clog it up.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-12-2002, 03:54 AM
speedfreak's Avatar
speedfreak speedfreak is offline
Send a message via AIM to speedfreak Send a message via MSN to speedfreak
It really sucks when you dont know that your pump pickup screen has a hole in it and those little stem seal bits lock up three pumps on a rebuilt block....
Also, if the engine has alot of miles, the main bearings could be getting worn, causing the oil pressure to go down when the oil gets hot and thins out.
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar.
1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc.
'95 Honda XR600-10.5:1, 628cc, ported head, & more.
03 mustang gt sputter/miss ndean52 Mustang Problem Diagnosis 4 11-23-2010 03:42 PM
rebuilt engine misses after 375 miles? rfb427 F-Body Problem Diagnosis 2 02-25-2009 08:25 AM
99 Dodge Neon Missing After Multiple Repairs shell.lynn 1st Gen 95-99 2 02-22-2009 01:32 PM
Help...Missing link rotaran LeSabre 2 08-09-2005 04:51 AM
HELP!! Missing Fujimi AE86 Instructions digitalheat Car Modeling 3 09-05-2002 07:18 PM
