Old 04-24-2005, 01:45 PM
la-z-boy la-z-boy is offline
EGR flow out of range (P1408)
EGR flow out of range (P1408)... What to do to fix this problem?
Old 04-24-2005, 06:04 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: EGR flow out of range (P1408)
Don't know what year you have, but look for the EGRV(Exhaust Gas Recirculation Vent) solenoid. See if there is vacuum coming through it at idle.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-25-2005, 01:59 PM
I have 1998 taurus.
Old 04-25-2005, 02:00 PM
I have 1998 taurus.
Old 04-25-2005, 06:47 PM
way2old's Avatar
TOKEN HILLBILLY
OK Check the vent solenoid. I guessed at a 98 when I looked for the repairs.
Old 04-29-2005, 08:50 AM
GPFred GPFred is offline
I would also check the backpressure sensor, that seems to be the more common problem with the EGR valve setting off a code. I just replaced mine. I would also try cleaning the EGR first, off the car of course. Good luck.
Old 05-01-2005, 12:58 PM
Which one is backpressure sensor, I can't find it.
Old 05-01-2005, 06:40 PM
way2old's Avatar
TOKEN HILLBILLY
Do you have the 2 valve or 4 valve engine? The 2v follows.Backpressure is the DPFE sensor. It is a little rectangular box about 3 inches long and 2 inches wide with same connections. Shouls sit on top of engine near the center rear on a bracket.If it is a 4 valve, it may be a small 1 1/2 inch square box that is buried under the intake. Same connections.
Old 05-01-2005, 07:59 PM
i replaced that backpressure sensor. but computer still shows P1408 code. ?????
Old 05-01-2005, 08:50 PM
sfontain sfontain is offline
Re: Re: EGR flow out of range (P1408)
Did you have the codes cleared? If not then you will need to drive several cycles before it can turn off by itself.
Old 05-01-2005, 09:00 PM
if I disconnect battery for couple hours will it clear codes?
Old 05-02-2005, 09:18 AM
If you have an Advance Auto Parts in town, they will loan you a code reader to clear the codes. Or they may do it for you. Usually with no charge.
