Old 04-24-2005, 11:52 AM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
! Files retaining space...
Ok I have numerious files on my comp lately I have been transfering all the info into one or two large folders but when I transfer the files out an onto the other file the empty file STAYS THE SAME SIZE! I transferd 455 mb worth of stuff the old folder appears empty an yet still stays the same size an its slowing my comp. Anyone have any Ideas?
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
Old 04-27-2005, 09:43 PM
Franko914's Avatar
Franko914 Franko914 is offline
Re: ! Files retaining space...
Hello jcsaleen,
Try deleting the folder after it's emptied.
Run your disk defrag utility -- that should free it up.
Franko914
US Supreme Court Upholds the First Gun Law: The Second Amendment
Old 04-28-2005, 02:59 PM
jcsaleen's Avatar
Re: Re: ! Files retaining space...
I tryed deleting some of the empty folders wont delete because "they're being used by other programs" Ive restarted an all an still
" ~ Igor
Old 04-28-2005, 09:06 PM
Franko914's Avatar
Re: Re: Re: ! Files retaining space...
You never mentioned what OS you are running. You could have hidden/system files in the folder. Change your folder display properties to display ALL files, including system and hidden files. Delete what you think is safe to delete. Boot up into Safe mode and try it then. Boot up into DOS if you can and try it then. Shut down all programs (Task Manager) and try it then.
Old 04-28-2005, 09:47 PM
jcsaleen's Avatar
Re: Re: Re: Re: ! Files retaining space...
Im running Xp pro.
" ~ Igor
Old 04-29-2005, 12:47 AM
uranium235powered's Avatar
uranium235powered uranium235powered is offline
Try re-naming the file, but I doubt that will work. Is this file for an application or something?
Try Ctrl + Alt + Del -> select Task Manager or something similar, and under the processes tab, select the applications that you can't shut down there and click on End Process.
** Disclaimer: If you lose any valuable data or if your PC fucks up, I hold no responsibility. Do this at your own risk**
Originally Posted by CassiesMan
Just be happy it wasn't one of the ultra rare Ford Mustang GT-R, with a Turbo intercooler rotary V8.
Old 04-29-2005, 02:35 PM
jcsaleen's Avatar
Tryd renaming doesnt work. It doesnt say which processes are running so I cant do that either.
" ~ Igor
Old 04-29-2005, 02:42 PM
sirsmiley sirsmiley is offline
when your pc is booting up, hit f8 before you see the colourful XP boot screen (just keep hitting f8 after the bios part and it finds your drives)..pick boot with safe mode and then delete them...i imagine you have viruses and spyware, use mcafee stinger and lavasoft adaware and spybot, all other spyware utils are garbage imo
Old 04-29-2005, 07:24 PM
jcsaleen's Avatar
I have norton anti virus an the web defender as well. I also run adware to an I use mozilla its seems pretty unlikely its a virus.
" ~ Igor
Old 04-30-2005, 02:35 PM
Franko914's Avatar
Have you tried to run your disk defrag utility yet? This should at least free up the sectors used by the files you have already moved out of the folder.
