Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-24-2005, 11:45 AM
trippinsid trippinsid is offline
Question trouble code 51
is the pcm bad or can something else cause this code???
thanks
Old 04-24-2005, 12:32 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: trouble code 51
What kind of saturn do you have. Any particular year?
Old 04-24-2005, 12:34 PM
Re: Re: trouble code 51
92 sc2
Old 04-25-2005, 01:32 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: trouble code 51
http://www.differentracing.com/tech_...es/dtc/51.html
reset the PCM by pulling the PCM B fuse for 15 seconds. if the code comes back, the PCM is bad
Old 05-01-2005, 09:03 AM
Thanks i will try that. Also after i pulled the code the check engine light stayed on and the car ran fine for 2 days. Then it went back to stalling out and the check engine light went out,so i pulled the code again,this time didn't get no code but check engine light came back on and car ran fine.. Could it be possible short?????
thanks
Old 05-01-2005, 03:00 PM
Re: trouble code 51
i haven't seen this code before, so i'm going to stick with recommending replacing the PCM
