Old 04-24-2005, 09:39 AM
chevy94 chevy94 is offline
Difference between Vortec & Non-Vortec?
I just purchased a 1994 Astro CS. The Vin engine code is Z for the 4.3L V-6. The valve covers say Vortec V-6.
My 1989 Astro has the standard 4.3 V-6 Non-Vortec. Can someone explain the difference between the two engines? Many Thanks.
Old 04-27-2005, 07:44 AM
drew300 drew300 is offline
Re: Difference between Vortec & Non-Vortec?
Marketing
Sounds impressive, "Vortec", maybe even masculine.
Old 04-27-2005, 01:03 PM
Kings-x59 Kings-x59 is offline
There's a blurb on this website that describes what a vortec engine is.
http://www.gm.com/automotive/gmpower...ngines/vortec/
Old 04-27-2005, 01:48 PM
I thought swirl-technology was decades older than the Vortec engines.
It would be quite a trick to non-swirl (laminar flow) a fuel/ air mixture into an explanding cylinder through an off-centered poppet valve, in a wedge-head.
That would be one heck of a useless accomplishment!
Maybe i should try for a research grant.....
Old 04-27-2005, 08:24 PM
LMAO!
Work in an alternative fuel derived from oil and you are sure to to get millions in grant money!
Old 04-28-2005, 09:19 AM
tom3 tom3 is offline
The actual name is more marketing than anything else. Consider a Vortec 2.2 four banger, what a joke. Maybe a Dodge Magnum four cylinder? Sure it is. But the 4.3 Vortecs were a pretty big improvement over the throttle body, especially when they improved the heads in the mid 90s. Sure not without their problems though. The Vortecs had improved air flow, port injection, better cams, balancers, electronics, and that dreaded electronic EGR valve.
Old 04-29-2005, 08:30 PM
yes the dreaded EGR, the part that got so increadibly expensive when OBD 2 went into effect.
But, after the "vortec" arrived the horse power on the 4.3's did start to go up.
I suspect it was nothing more than a half ass port and polish on the heads.
Old 05-03-2005, 08:20 AM
But don't forget, every other manufacturers' horse power went up over the last decade too, using non-Vortec technology.
Old 05-04-2005, 09:28 PM
man ya can't get nuthin past Drew canya!
Old 05-05-2005, 08:08 AM
Hey, I try.
Now if only I can get my van to start.....
(see other posts)
Old 05-05-2005, 08:49 AM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
The fact remains, the more air you can put into a cylinder, the more you are going to get for you bang. This is something you cannot get around. You need as much fuel and air you can pack into a cylinder for the most power. You can pack more air getting to swirl while entering. This is not hype. There are people out there who do more study and have the means to do the studys.
Old 05-05-2005, 08:46 PM
Going from 12 - 14 psi fuel delivery to 50 to 60 psi alone will pack more air/fuel into the cylinder alone.
Also made the fuel pumps reeealy expensive.
Old 05-09-2005, 08:35 AM
Interesting. Maybe I missed the boat, and "Vortec" refers to the vortex started in the intake manifold by the 60 psi fuel pushing more fuel/air into the cylinder....
Poor mans' supercharging?
Old 05-09-2005, 10:46 PM
It's not just the more air you can put in, but how well you can atomize the fuel into the air. Gasoline, even the high octane, is not all that highly refined a fuel. A fair amount, even in these days of all the additives, goes out the tail pipe. Now the catalytic converter takes care of some of the excess. So the vortex effect mixes the fuel / air a bit better and more bang for the buck. Although I think this is a lot of marketing hype as well. I think GM did a little better job on the ports, put a bit of spin on the in-flow and voila...vortec.
Old 05-10-2005, 05:45 PM
rksnc's Avatar
But if you get more air into cyl , then are you not then also getting more fuel. And with all the sensors at work , computer is working to keeps fuel air ratio at 14:1.
