Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 04-24-2005, 03:33 AM
twitch24 twitch24 is offline
what we got
alright, i know i have had my car for a while, and i am hardcore KA24DE-T, but alot of people were talking shit about the KA motor and telling me the only way to make my car fast, was to swap a SR20 in to it, at this point, i was laughing at everyone telling them that all they have to do is wait, and finnaly 6 months after i got my car,91 240sx coupe DOCH 5 speed, i have got my turbo setup together, so now that i have spent some $$ on this stuff, all of my friends are still like "u wont run any faster than a hi 13 of low 14", id like to hear what u guys have to say about this heres the list
1)B.D. stage 2 kit-57 trim
2)clutch spec stage 3 from B.D. also
3)full exhaust from B.D.(as u can tell by now i really like their stuff)
4)enthalpy tuned ecu
5)B&M shifter
6)gage pod
7)boost gage
8)oil pressure gage
9)j30 LSD
10)z32 mafs
and thats all i can think of now, is have to go check everything right now,id like to get some feedback on this from u guys, what u thinking it is g
gonna run???
Old 04-24-2005, 05:26 AM
orestes's Avatar
orestes orestes is offline
what about injectors? what size injectors are you going to have running with your Enthalpy tune that makes a big difference. i would say faster than a high 13 though. but again it can totally vary you need to be more specific.
P.S. #'s 6-8 are just gauges ("gages") and #9 is a cheap solution that will cost you 1/10ths of seconds.
"I got that hustle in my genes like high blood pressure" -E-40
Old 04-24-2005, 08:47 AM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: what we got
well the setup seems to be pretty good but i personally think you'll be running about as fast as a sr20 (not just being bias'd) but with out injectors and running stock boost...im thinking you'll hit around 225 whp'ish...so thats as fast as my sr20...and my motor is still stock. but you add some more boost and you'll blow away any sr motor with the same boost level, and get some injectors atleast some 550's...other wise your pretty much going to be be running lean.
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 04-24-2005, 08:49 AM
Re: what we got
btw that should all result in atleast a around a 13.5 1/4...id say atleast that
Current cars:
Old 04-24-2005, 12:13 PM
TatII TatII is offline
yeah the info without the injectors dont' tell anything really. and what psi are you running? that also is a big factor. if you have the proper fuel setup you should be able to run 14 psi on that turbo. with 14 psi that should be a high 12 second car. without the proper fuel, running small 370cc injectors, 9 psi is the safe limit with that i would have to say high 13's. also your friends are talkin all this smack about high 13's being slow. what do they drive?
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 04-24-2005, 12:19 PM
s13dr1fter s13dr1fter is offline
Send a message via AIM to s13dr1fter Send a message via MSN to s13dr1fter
Re: what we got
Well if he is running the stage 2 kit from B.D. it comes with 52lb injectors.
Old 04-24-2005, 12:24 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: what we got
the kit comes with 52lb injectors which convert to 546cc.. which will do.. other than that the kit looks good, and for $2600 you'll be just as quick as a stock sr like driftking said. up the boost a little and you might dip into the high 12s
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 04-24-2005, 12:25 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: what we got
isnt boost designs out of Panama city florida?
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
D-Bo's Avatar
Re: what we got
you beat me to it
Old 04-24-2005, 12:26 PM
D-Bo's Avatar
Re: what we got
and yes, they're in panama city
Old 04-24-2005, 12:29 PM
Re: what we got
So the stage 2 kit form B.D. is about the same as to a stock sr?
Old 04-24-2005, 12:31 PM
doin it sidewayz
Re: what we got
beat u to what?
Old 04-24-2005, 12:34 PM
D-Bo's Avatar
Re: what we got
s13dr1fter beat me to posting the fact that the kit comes with 52lb injectors.
the conversion is simple. if you have the flow rate in lbs, then multiply by 10.5. if its in cc and you want lbs, divide by 10.5.
anyways, with this kit on and everything tuned properly he'll be about the same as a stock sr. i'd say side by side, the ka-t would win but in the higher rpm range the sr would dominate.. thats two stock turbo engines
Old 04-24-2005, 12:38 PM
doin it sidewayz
Re: what we got
if they were putting out the same power wouldnt the sr have a slight advantage because it is lighter?
Old 04-24-2005, 12:39 PM
Re: what we got
thanks alot D-Bo. I think i decided to go sr now.
