Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-24-2005, 01:25 AM
gonzoar gonzoar is offline
starter replacment/passport/rodeo
with truck on jackstands lift engine a couple of inches the starter
will almost fall out.take it to rebuid shop most will do it for under
100.00 and warrenty it good luck
Old 04-26-2005, 07:09 PM
nosmaharba nosmaharba is offline
Re: starter replacment/passport/rodeo
How accurate is this compared with a '98 3.2 V6? I'd hate to get about 1/2 way done and then have to call a tow truck.
Has anyone else accomplished starter removal/replacement this way?
thanks
-Nos
Old 04-27-2005, 08:35 PM
dowlings3 dowlings3 is offline
starter
Nos,
I am getting ready to change out my starter this weekend. I have heard there are only 3 ways to get the starter out. Jack the engine, take off the exhaust pipe at the manifold, or disassemble the starter and selenoid in the engine compartment and remove seperately. I was able to remove the starter motor but not the selenoid. I will probably jack the engine first. Let me know what you did.
Matt
Old 04-28-2005, 05:46 PM
Cat Fuzz Cat Fuzz is offline
I removed the exhaust pipe. Get some PB Blaster and soak the studs/nuts before wrenching.
Old 07-31-2005, 04:31 PM
shakagg shakagg is offline
I have a '98 Rodeo and just accomplished a starter R&R this morning. When I removed the two mounting bolts it practically fell out. As a matter of fact, if not for the positive cable being attached, it would have fallen and hit me in the face. I had no problem with the exhaust being in my way. Entire job took less than half an hour.
Good luck.
