Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-24-2005, 01:57 AM
team_apocalypse team_apocalypse is offline
Send a message via AIM to team_apocalypse Send a message via Yahoo to team_apocalypse
Exclamation 95 eclipse rs has low idle and stalls.....help!!!
Okay....here's the deal. I aquired a 1995 Eclipse RS non-turbo with 86K on it. The engine was shot because the preivous owner drove through deep water and it got sucked into the engine. The rod in the first cylinder actually broke. I had the block redone, put in new rods, pistons, rings, seals, and bearings. Had the head redone too. Got all new gaskets, new timing belt, iridium plugs, 9.5mm wires, light-weight underdrive pulley kit, adjustable cam gears, header, high flow cat, and an Air Mass exhaust from Holley. I figured that would make things all better. Boy was I wrong.
It starts right up, but the idle bounces between 200 and 600 then stalls out. If I lightly press the gas and bring it to 1000, it sounds sooo beautiful. As soon as I take my foot off, it stalls out.
Trying to figure out the trouble codes. Check engine light blinks once for about a sec, pauses and then blinks twice for about a sec each, pauses and then blinks five times, pauses and blinks five times again.
What the hell is wrong with my car?? I can drive it as long as I don't let it idle at a light or stop sign. I just want to fix this once and for all.
Old 06-10-2005, 10:35 AM
suz_in_idaho suz_in_idaho is offline
Wink 95 eclipse rs has low idle and stalls.....help!!!
OMG!!! I get the same codes!!!I joined this site because I can't figure out nor can 3 different mechanics including the dealer... what the %$#@* is wrong with my 1995 eclipse!!URRrgggg!
I hope someone out there will know exactly whats going on here!
Did you do the "check engine" light, click 5 Xs, wait for and count the blinks? Thats how I got my codes.
Okay I'll try make a long story short, and I am a girl.
This has been going on for months!!! UUUrrrgggg!
Car running great!....No problems..Good to Go!
I swapped my BF 16 y old son vehicles so he actually had been driving the eclipse, he blew my clutch out!! %$#@*^
I had it replaced (Thats another Prob. way to much play... pedal to to loose ,not stiff and have to let up on it about 6 inches before car moves as opposed to 1/2 inch like before mechanic would not adjust!!! SAID and I quote" because people used to complain about to much stiffness when new clutch were installed ALL the manufactures got together and produced a standard looser clutch and no adjustment could be made, I'd get used to it! And my stall problem had nothing to do with clutch install...I told him according to the 95 Mitsubishi Eclipse Chilton repair guide the clutch could be adjusted for "to much play" it has the specs for doing so...He said and I quote " You can't go by that book...it's to old!!! my mouth was AGAPE!! needless to say my car will just hit 0 while going various speeds, sometimes when i push gas..it clips right back to current speed and sometimes it just stalls, it will start but only if the "check engine" light comes on when I turn key...if not it just cranks...some days it doesn't do it at all, and some days I can't get around the block...another shop said its the cam shaft sensor or crankshaft sensor according to their diagnostic test...should replace both....UUUrrggg! they have crankshaft on hand (have to order the other)so they throw that one on and tell me its fixed!! Wahoo! clipping along 50mph rrrruunnttt -0- again...stall...wait...start...stall yadda yadda! take it back to put my good sensor back on and replace the the cam sensor after all they said it was one or the other. NOT!! they never replaced the cam and they left the"new" crank shaft sensor I didnt need on....@#$%^Took it to Mitsubishi and they cant find anything wrong...it would not stall or zip to -0-...that was 3 months ago 1000's of $$$ 3 mechanics NO RESOLUTION!!! I'm ready to loose my mind!!! So WHAT IS IT!!! HELP MEEEEE!
Old 06-23-2005, 11:06 AM
fredie_gie fredie_gie is offline
Send a message via Yahoo to fredie_gie
did you ever figure it out what is making the car loose rpms and stall
Old 06-23-2005, 02:47 PM
Wick3D-PimP Wick3D-PimP is offline
Send a message via AIM to Wick3D-PimP
hey im not sure if im too late on this post, but i believe there is a simple solution to this problem... i wanna call it the speed sensor if I remmber right... there is also sensor on the trottle body called the throttle postion sensor you might wanna check it too... but i believe the bounceing idle is from the speed sensor
1996 Eagle Talon ESI
