Old 04-24-2005, 12:00 AM
Leonard_Vista Leonard_Vista is offline
2001 Cavalier-Car Overheating
2001 Cavalier w/ 82,000kms. My car started overheating today, after only a short drive to work. Rad is fine, not making any noises, I'm assuming its the thermostat. If anyone has had this problem, please post on how much it costs (Candadian or American), if it's easy to do? Thanks in advance.
Old 04-24-2005, 12:17 AM
pontiacfan84 pontiacfan84 is offline
Hi,
Overheathing could be a lot of thing!water pump...head gasket blowned...some water line.....But the thermostat could be the problem too!I change mine thermostat on my 95 sunfire 2,2...It cost 16 dollars canadian....And the job is almost easy tio do....Keep in mind that you will need to adjust your water level
Old 04-24-2005, 01:24 AM
S_chevy S_chevy is offline
Re: 2001 Cavalier-Car Overheating
overheating on a short drive to work, Did you sit in traffic? or was the car always moving?
If you were doing a lot of stop and go and sitting it could be the fan is not kicking on.
"War is cruelty. There's no use trying to reform it, the crueler it is the
sooner it will be over."
-William T. Sherman
Old 04-24-2005, 01:34 AM
No sitting in traffic. Was a 10 minute drive, a couple of stop signs and lights, nothing major. The car has been babied and everything was recently checked out. Thanks for any advice.
Old 04-24-2005, 06:59 AM
well then you are most like on the right track thinking it is a thermostat or water pump. I would start with the thermostat replacement should be more then $20 for a new one.
-William T. Sherman
