Old 04-23-2005, 11:21 PM
prginocx prginocx is offline
'94 truck interior lights question
They don't come on at night when the door is open. Key in buzzer works fine though so both door switches are good. Plus they can be manually switched on with the dash dimmer roller switch.
Is there some sort of override ? I just got this truck but isn't it normal for the interior lights to come on when the door is open ?
Old 04-24-2005, 07:01 AM
sitdusa sitdusa is offline
Re: '94 truck interior lights question
To the left of the light swtich there is a dome over ride button, make sure its not pushed in
Old 04-24-2005, 07:45 AM
benw benw is offline
mine is like that too. I think the connections in the door switches faded out because I used to be able to jiggle it and it would come on but now there is nothing
Siverado's are one of a kind. 252,000 miles and counting.
Old 04-24-2005, 10:57 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
prginocx, probaly button sitdusa explained.
Benw, it is very common for the door pin switches to go out on GM trucks/SUV's. Easy to replace, and only about $3 to $4 at the dealership. If and/or when you go to replace them, I recommend taking your glove box out and reach your hand in there to push the switch out as you pull on it from the other side. Helps to wiggle it around from inside the dash while pushing out.Thats for the passanger side. Drivers Side, you can fish your hand around all the wiring and reach it fairly easily and do the same (push w/ one hand, pull with other). Once you po them out, then disconnect the harness, plug onto new one, and snap it back in. Done
