Old 04-23-2005, 10:43 PM
4500 4500 is offline
turbo lag
how can i get the turbo to come in faster? I want a little smoke out the ex
Old 04-23-2005, 10:44 PM
Re: turbo lag
thats on a 97 f350 with 7.3
Old 04-25-2005, 01:31 AM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
Re: turbo lag
All i know is installing a heavier spring on the wastegate will allow longer boost. This may also allow for an earlier boost but not likely.
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 04-25-2005, 09:03 AM
Re: Re: turbo lag
there must be a way to trick the computer into letting the fuel pressure come on sooner, in the big truck motors you can adjust the air valve
Old 04-25-2005, 05:36 PM
tturnpaw's Avatar
Re: Re: Re: turbo lag
Good to know!
LS WHAT?
Old 04-25-2005, 08:57 PM
yotermanic yotermanic is offline
Higher fuel pressure doesn't mean a thing on the 7.3...most will run without the fuel pump even on. The actual injection pressure is what will cause more fuel and atomization. This is controlled by the ICP (Injection Control Pressure). Most chips up ICP by a considerable amount. Bigger exhaust will allow your turbo to spool up faster, but be warned, in higher altitudes with less-dense air, the turbo will over-spool if there is no backpressure. Remember, though...parts for diesels are expensive and more power usually equals more wear and tear.
