Old 04-23-2005, 08:29 PM
chevygirl82 chevygirl82 is offline
Question college report information
If there is anyone that can help me with this term paper, I greatly need it (to graduate!!!)
I know little about Fords and have been given the topic of this:
2004 Ford F250/F350 Diesel fuel system
I have a lot of info about HEUI and the PowerStroke itself, what I need is ANY info PCM on controls (of fuel sys.) and system voltages.
PLEASE HELP???
Old 04-23-2005, 10:05 PM
ModMech's Avatar
ModMech ModMech is offline
Re: college report information
The EEC operates at 12V input (chassis power), the sensors are all "3 wire" (power, ground, signal) for more accurate readings and fault detection, the HEUI system is 110-120 Vdc, in this way you get the power (watts = V x A) you need w/o using really thick wires.
The ECM takes signals from various sensors:
Temperatures, pressures, throttle position, vehicle speed, engine speed and then calculates load. From load and temp, it "looks up" the appropriate fuel and timing settings. Fuel is controlled by how long the injector is energized, and timing by WHEN it is energized.
The HEUI injector uses pressurized oil (850 - 3000 PSI) to push fuel which comes to the injector at medium pressure, into the engine under a piston in the injector at very high pressures 5500-21,000 PSI.
Old 04-24-2005, 05:46 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
How much do you want? Send me your e mail and I will send info when I get a free minute. If I get it tonight I can get it this evening or early tomorrow. Have access to Ford manuals.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-25-2005, 02:48 PM
Thank you so much for help. I greatly appreciate it. That was what I needed.
Thanks again,
Amanda (Chveygirl82)
