Old 04-23-2005, 08:04 PM
crusty dad crusty dad is offline
Angry parking brake problems
I just installed parking break kit (new shoes, adj. star, boot, lever, hardware, ect.) It's better than it used to be but it still won't hold on a steep driveway in neutral. Has anybody else experienced this? Maybe the drum inside rotor is worn out and oversized or maybe I should try turning adjustment star out some so the shoe drags a little. What really sucks is you have to take off wheel, caliper and rotor just to get to the star. Any thoughts?
Old 04-23-2005, 08:25 PM
dr_of_lovephd dr_of_lovephd is offline
Re: parking brake problems
I don't mean to state the obvious, but did you make sure the cable is tight enough. Sometimes it can streach with a lot of use, and then it will not fully engage the parking brake.
Old 04-23-2005, 11:36 PM
norwood's Avatar
norwood norwood is offline
I believe my Haynes repair manual says to adjust the park brake shoe out to where it just drags the drum when you try to put it back on, and then just back it off a little for clearance. I agree, it is a pain in the ass to adjust.
'99 Silverado LS
stock 5.3L
clear corner lights
vent shades
Ford torsion keys in front
Tuff Country Add-A-Leaf
Old 04-23-2005, 11:55 PM
DWW.ARU DWW.ARU is offline
After adjusting to snug fit on drum reinstall, try backing up several times and using heavy braking to stop. they should self adjust themselves for a tighter fit, allowing better pk/brk.
Old 04-24-2005, 09:34 AM
cable seems tight enough, I even adjusted it all the way out.
Old 04-24-2005, 09:39 AM
I think backing up for break adjust is for drum systems only not the combo of disc /parking break shoe.
