| Let's get Technical! Discussion for hardcore in-depth motor heads! |
rotten egg smell
well my car was running fine, i have left the lights on and let the battery go dead about 4 times now, it was starting to have some hard starts but latly it was seeming to have fixed it self. about three days ago i notised that everytime i drive my car hard the cabin is overwelmed with a rotten egg smell. i'm pretty sure the cat is going out or maybe the loss of power with the batterey is making it so the cat wont fire at the right time. i dont know, but last night before going out to the races i noticed my stereo would crackle for a few seconds every once and a while like the deck wasnt sending enough power, and then to top it off, the tach and speedo will turn off if i'm using the stereo and the power windows are getting slower and slower. would the cat or exhaust problem be the result of a power loss due to a bad battery?
Re: rotten egg smell
no, check your bat and alt. then replace your cat..
after your car is started by the battery all electrical is run off your alternator. by cat do you mean your catalytic converter? what do you mean by your cat "firing"?
88 Honda CRX Si - B16 90 Honda CRX Si - B20VTEC |
by cat yes i mean catalytic converter, once the cat is full it will fire a spark setting all of the build-up to burn. useally it makes a disscusting fart smell, but this is ten times worse! it will make you sick and light-headed. another question, are there any sencors i would have to deal with if i were to cut the cat out and just straight pipe it?
you have no clue how a catalytic converter works, do you
D16Y7/D16Y8 mini-me swap turbo coming this summer |
hot or burning coolant smells like rotten eggs to me. You might have a coolant leak or something under the hood and it is venting into your cabin.
![]() Empty Pockets Racing Member #1 |
Re: Re: rotten egg smell
94' Del Sol VTEC (B16A3) SOLD. Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles. |
just add some fuel cleaner to your car and the smell should go away. my moms camry had that smell and it went away with a bottle of cleaner, interestingly my other friend who also owns a toyota has that rotten egg smell. but ive put in a bottle of cleaner about once every other month and i havent smell eggs once
I had the Same exact problem about a week ago. I checked under the hood and I saw that my battery was smoking and smelled like ''rotten eggs'' yum. Turned out that it was my battery and went and got it replaced. Now the smell is gone and good as new.
