Old 04-23-2005, 06:09 PM
ggibson19 ggibson19 is offline
92 lesabre custom
My dash vents refuse to operate. A/C and heat controls work fine. The fan blows at any selected speed. I recently had the entire system blown out, therefore lots of free air movement. Now the "doors" seem stuck open at defrost/defog. Is this an electrical control panel problem, or simply mechanical? System is Manual. In VENT MAX NORM & BILEVEL positions, air blows at windshield at any temperature setting.
Old 04-23-2005, 08:37 PM
yogi_123rd yogi_123rd is offline
Re: 92 lesabre custom
The vent system works on engine vacuum. The heater's default when there is no vacuum is to send air out the defroster. Lack of vacuum is your probable cause of your problem.
The heater/ac source vacuum line is found under the hood, to the left of and below the master cylinder. Look for a rubber vacuum line going to a connection on the firewall. This line usually falls off from dryrots.
Old 04-24-2005, 12:20 PM
Post Re: Re: 92 lesabre custom
to yogi_123rd - Thanks for the info. Found it easily, and the vacuum line had indeed fallen off. Will replace it tomorrow.
