Old 04-23-2005, 05:59 PM
riff22 riff22 is offline
dash lights all on?
just today my dash lights are on, battery, brake, coolant and i think thats it. everyonce in awhile they flicker. does anybody know what this is? i thought maybe the alternator, because the rpm goes up and down with the wipers. but i took the neg terminal off the batter while it was running to check the alternator, and the car was still running. if it shuts off then you have a bad alternator, at least that was how i was tought to check it.
-1995 Eagle Talon TSI AWD
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-walbro 255 fuel pump
-550cc injectors
-pocketlogger
-2.5 full exhaust (no cat)
-30 psi bov
Old 04-23-2005, 06:00 PM
Re: dash lights all on?
oh and also noticed since this started my digital a/f gauge runs at like 1.01 or so at wot. before it was like .98 or so.
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-23-2005, 07:23 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
its your alternator. Mine did the same thing it was only putting out 11 volts. Them 3 dashlights came on in mine to and also would flicker. I had mine rebuilt for $50
Old 04-23-2005, 09:50 PM
ned032002's Avatar
ned032002 ned032002 is offline
I concur on the alternator being bad, when mine went bad I could tell because when I hit the brakes those lights would come on as well as an idle drop then a pick up right after. Good luck with the fix, while your at it might as well check the battery or just change it, I dunno just a thought.
Old 04-24-2005, 09:25 AM
well i have a safc2 and it says 13.8-14.1 on the battery
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-24-2005, 09:42 AM
1992eclipseGS 1992eclipseGS is offline
I would say your alternator. Go get your alternator tested before its too late. My car was having similar problems. I just ignored it and figured i'd deal with it later. A little less than 2 weeks later my car died right as I was turning into a parking lot. My alternator was only reading 9 volts.
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 04-24-2005, 12:03 PM
ok, i will get it tested.
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-24-2005, 04:34 PM
found out the alternator wires that plug in where loose the plug was half way off. fixed it thanks for all the advice everybody
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
