Old 04-23-2005, 05:18 PM
rspecht rspecht is offline
A/C Leak - Pointers on Where to Look
Have a slow leak in my A/C on a 92 VR-4. Put in the dye to try and find it and am still looking.
Are there parts of the A/C system which are more likely to leak and I should check there? Also, is it possible for the A/C leak to occur inside the car?
Thanks
Old 04-23-2005, 07:30 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
My AC isn't blowing very cold, how do I check to find out whats worng? Should I just take it to midas or somthing?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 04-23-2005, 08:50 PM
Re: A/C Leak - Pointers on Where to Look
You can go to Autozone and purchase R134A refrigerant, provided that's what you are using in your car. Earlier models used R12, but most have been converted.
However, this is only a stop gap, since you really need to find the source of the leak, as I have been experiencing.
Old 04-24-2005, 01:24 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: A/C Leak - Pointers on Where to Look
I got a leak in my car that wouldnt be seen if I didnt hear it. Its actually the condensor itself that is leaking and its leaking on the side facing the radiator. How I got a hole there I will never know.
