Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-23-2005, 11:12 AM
zenit27 zenit27 is offline
Rodeo 97 Burning Rubber Smell
Everytime that i drive it for more than 10 miles, when i get out there's a strong smell of burning rubber.
Any ideas.
I have a 1997 Rodeo with 77K miles on it.
3.2L V6 Engine, Standar 5 speed transmission with 4WD.
Old 04-23-2005, 11:45 AM
Cat Fuzz Cat Fuzz is offline
Get up under the car and look for something rubbing on the tires or maybe something wedged up against your exhaust that could be melting or burning. Thats all I can think of right now.
Old 04-23-2005, 12:11 PM
rodeo02 rodeo02 is offline
My 2002 has done that since new. Never did determine if it is from brakes, exhaust, cooling system, etc... Nothing has ever failed or burned up. You only notice it when you pull right into the garage after a hywy run. Some have speculated it's undercoating close to or dripping on something hot, but my 2002 has no spray-on, sticky type OEM undercoat . I've often wondered if it's from the vast amount of RTV sealer on every engine/powertrain joint giving off the rubber smell, or maybe an exhaust hanger near the HOT cats.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-23-2005, 07:12 PM
Wink
Or maybe you just need to keep your foot out of the TBI when the light goes green?
Old 04-23-2005, 07:37 PM
Question Re: Rodeo 97 Burning Rubber Smell
Thaks for the prompt response.
Can someone tell me what is the TBI?
Old 04-23-2005, 09:26 PM
Re: Re: Rodeo 97 Burning Rubber Smell
Well, I was joking but TBI stand for Throttle Body Injector, or something.
Old 04-24-2005, 05:37 AM
'Trying' to keep that under control with gasoline prices they way they are lately!! (avg $2.30/gal)
G/luck
JOel
Old 04-27-2005, 10:16 PM
jimstl99 jimstl99 is offline
I had this on my 94' and it turned out to be rear axle seals leaking and forming a big carbon deposit on my rear brakes.
jim
Jim in StL
01' Trooper LS, 265/70/16 Bridgestone Deuler AT Revo's, OME 919 Springs, OME Shocks, Poly Bushings
Old 04-28-2005, 01:02 AM
txsoulfly txsoulfly is offline
Send a message via AIM to txsoulfly Send a message via Yahoo to txsoulfly
jim
This is what is happening with my 98. Rear brake dust shield is covered in diff oil. Seal needs to be replaced.
Mando
1998 Rodeo S 3.2 3" sus lift, Dueler Revo's, Aisin hubs, and Aussie locker.
