Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 04-23-2005, 03:54 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
bad gas milage Help
i have a 88 supra turbo gettting the worst gas milage not sure how bad it is because my spedo dosnt work but i know i just put 20 bux in and it got me like 50 miles. no egr installed i just got the car so it could be anything i just replaced wire harness and cam position sensor. getting code 43 51 52
Old 04-26-2005, 01:48 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: bad gas milage Help
43 - STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
--IGNITION SWITCH/CIRCUIT
--ECU
51 - SWITCH SIGNALS IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
52 - KNOCK SENSOR SIGNAL
--OPEN OR SHORT IN KNOCK SENSOR SIGNAL
--KNOCK SENSOR/CIRCUIT
ECU
I would check/replace the knock sensor wiring/connection, and check/replace the TPS wiring/connection - and TPS if necessary. Clean the connections with electronic connection cleaner. Knock sensor wires are commonly damaged or connections dirty.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-28-2005, 01:11 AM
checked codes again after 1 full tank of gas and no more codes apear. still bad gass milage. new knock sensor new tps and set tps.
Old 05-30-2005, 11:44 PM
Brian R.'s Avatar
Resident Chemist
What about the knock sensor wiring? That gets damaged often.
Old 08-26-2006, 11:19 PM
mex.revolutionist mex.revolutionist is offline
you should try changing out the air filter, the fuel pump, or maybe even the pcv valve, spark plug and get a add in cleaner that you add with a tank of gas. i dont know if that would work for the supra but when ever ive had that problem with my rides thats what i have done and got great resolts.
