Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-22-2005, 09:24 PM
firefly386 firefly386 is offline
Send a message via AIM to firefly386
Exclamation Clutch pedal very easy to push
i just had the trans and clutch replaced. and now it is very easy to push to the floor..but is will ingage and disingage about 3 inch after i start to push on the pedal i know this is not right how do i ajust this so it will start to engage about 12to20% off the floor?
Old 04-23-2005, 11:30 AM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: Clutch pedal very easy to push
Do u mean that when u step on it, it just falls onto the floor very easy without wanting to be pushed? Clutch petals are suppose to be stiff (not too stiff) but stiff enough. I think its normal to have it disingage at 1/2 to an inch after u start to push the petal. Make sure they bleed the clutch right.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 04-23-2005, 11:46 AM
No it does not fall to floor but is easier than before i had it changed..i change to a cluchmaster dual frition clutch from a oem.. now there is less effort to push on it and it engages and disengages in a very small range. ..went i step on the clutch it start to disenage and if fully disengaged by half why..
the OEM start when i push on it and didnt fully disengage intill it got about 75% to the floor..
is this normal? can i ajust it any?
ty
