Old 04-22-2005, 09:15 PM
chughes94 chughes94 is offline
97 Blazer cutting out
Help with 97 LT Blazer. Had new Jasper engine put in about 47,000 miles ago. Gas mileage is not what is should be. Just rec. replace all O2 sen., plugs, and wires. Fuel filter has been on less than 10,000 miles. Been running great after plugs were changed, then yesterday it started cutting out. When you get to 1500-1800 rpm's it has nothing there. If you give it gas and go you see black smoke. Something is making run very rich. Anyone have any ideal's??
Old 04-23-2005, 01:43 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 Blazer
Alright, let's go down the list.
Have you ever changed:
air filter
Cap & Rotor
What plugs were used?
Also, I would take it back to who installed it because they could have installed the distributor a tooth off and the base timing is retarded.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-23-2005, 11:38 AM
Re: 97 Blazer
Yes the air filter was changed with the plugs, which are AC Delco Plat. The only reason I had to change the wires were because I broke an end off of one trying to get it off. The rotor cap was not changed. But I will check about the distributor. I have taken to another mech. because it has never run like it should 100%. They had made the same kind of comment as though they thought is was out of time but it has no timming adjustment.Is there any way I can check the tooth setting myself??
Old 04-23-2005, 12:05 PM
BlazerLT's Avatar
AF -Advisor
Re: 97 Blazer
Nope, take it back to the person who installed it.
You have a warranty.
Old 04-24-2005, 11:18 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Re: 97 Blazer
BlazerLT is absolutely right, if you had a jasper engine installed I would bring it right back hand them the key and say fix it! Get whatever you can out of a warranty, I know I did.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
