my blazer has 60,000 miles and runs fairly good, BUT...I can be driving it then it will just shut off..no warning (dash lights flash and door locks go on and off; sometimes SEL somes on) I can start it right up, then it may be fine for a few days then does it again. I have had it to the dealer twice (once stated battery bolt loose..tightened; next changed a spark plug) when they test drive it, it works fine. I get it back and a few days later happens again. went to garage 2 more times says no codes show up and that everything is ok. got it back on a Sat..Mon happened again...afraid to drive it. What could be wrong? HELP!!!!
Re: 1998 Blazer stalling
Clean and tighten your battery terminals.
Are you noticing any fuses blown?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: 1998 Blazer stalling
I would go to autozone and get the computer scanned for that code.
Possibly a security issue? Maybe a cat issue? Aren't the possibilities for this endless? Does the SEL shut off when it is running fine? I would get it scanned as soon as you can when the SEL comes on as BLazerLT Suggested
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
