Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 04-22-2005, 07:29 PM
tinytrixie's Avatar
tinytrixie tinytrixie is offline
Question synthetic tranny fluid
Hey Ryan or anybody, can you mix synthetic with dino? The mercon in ours is somewhat burned & I change 3 quarts every 3k (when I do oil)! The truck has 120k & I just want the transmission to go a bit longer. My thoughts on mixing synthetic is usually the flash point is higher so maybe the burning will be somewhat checked. I wouldn't want to flush & fill with synthetic because the massive influx of detergents would clean too much varnish. We have always had the tranny serviced reg with 4 full flushes during the first 100k and many 3qt changer thereafter. Any imput would be apperciated.
Old 04-22-2005, 09:21 PM
df2000 df2000 is offline
Send a message via AIM to df2000 Send a message via Yahoo to df2000
Yes, you can mix synth with dino, no problem.
On side note fluid can just do this much...And you change it so offen...
If fluid really smell some what burned you tranny has some mechanical or electric issui...Try add extra tranny cooler...
Old 04-23-2005, 06:46 AM
rodeo02 rodeo02 is offline
Sure, any modern synthetic ATF can be mixed with conventional ATF without issue. I wouldn't bother running an expensive synthetic ATF if you do regular dump & fills. That totally defeats the purpose of a synthetic lube.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-23-2005, 08:03 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: synthetic tranny fluid
What does 3 quarts of ATF cost? 10 bucks? Do what you state 10 times over 30k, you basically just paid for a flush. If you haven't dropped the pan yet to replace the filter it is about time.
If you are set on dumping 3qts of tranny fluid per change, I would save the cash and just use dino fluid.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-23-2005, 08:57 AM
tinytrixie's Avatar
It just bothers me that the fluid is smelling lightly burnt, not the worst I have ever smelled, if the synthetic will not burn as easily... it was just a thought.
