Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 04-22-2005, 02:47 PM
bjbmoglo bjbmoglo is offline
dash light
My dash light (instrument illumination, whatever) is out. I have checked the fuses and they are all good. No other problems. Can anybody give me some directions on how to fix/replace it? 86 Civic.
Thanks in advance.
Old 04-22-2005, 03:18 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: dash light
try the dimmer.. pull it out and wiggle the connecter behind it, had the same problem with my civic.
Old 04-22-2005, 05:53 PM
btw, i meant 88 civic dx. my bad. dimmer switch didnt work. Thanks though.
Old 04-23-2005, 01:18 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: dash light
there should be screws around the cluster, take out the cluster, remove the harnesses, pull it out and check the bulbs, their twist offs.
Old 05-10-2005, 04:07 AM
007COUPE 007COUPE is offline
you may want to go ahead and replace the whole cluster. Its not that expensive for that year civic.
Old 05-10-2005, 09:26 AM
uh... what do you mwan by cluster? how much is not expensive?
Old 05-16-2005, 10:53 PM
The Gauge cluster is the whole section with the speedometer, odometer, gas gauge, water temp, and rpm. If you check on ebay you may be able to get one for around 30-40 bucks.
Old 05-18-2005, 07:18 PM
Honda2Die42005 Honda2Die42005 is offline
Re: dash light
try the swich that turns on the light that happend to me and I changed that and it was fixed
