Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-22-2005, 02:02 PM
Russ06 Russ06 is offline
Question '94'Probe no Spark
Need help finding out why car has no spark? Turns over,dash gauges work, it's not timing belts. Have spark through distributer (I think). going down the road and the car died while in motion. ??????? Please help with any possible ideas or solutions. THANKS
Old 04-23-2005, 05:48 AM
bargersaudio bargersaudio is offline
Re: '94'Probe no Spark
Are you sure you have a no spark problem? If you have spark at the distributor you should have spark. You van check some fuses under the hood and at least one fuse in the inside fuse box could lead to this. You first must determine if it is a no spark or no fuel problem.
Old 10-03-2006, 08:58 PM
vonage003 vonage003 is offline
if you have fuel and good timing but no spark 93-94 probes are notorious for having bad distributors so 10 to 1 its your disty!
Old 10-03-2006, 08:59 PM
i have had to replace my distributor about 5 to 6 times now.....im sick and tired of this car...the engineers behind all of this suck!
Old 10-06-2006, 02:59 PM
CrossGT6's Avatar
CrossGT6 CrossGT6 is offline
Send a message via AIM to CrossGT6 Send a message via MSN to CrossGT6 Send a message via Yahoo to CrossGT6
Its a simple 20.00 lifetimee war fix. Every car has its problems in design but blame that one on Mistu they made that part.
Using a GM HEI Module you can fix the problem and have a lifetime part.
Its very easy here is a link to the guide:
http://forums.probe-enthusiast.com/s...ead.php?t=3208
Use the right forums (Probetalk, mx6.com and Probe-Enthusiast) and you will not only get parts cheap but will never have a huge problem again thats not solved within a few hours.
These are very simple and great cars. You just have to find the info you need ^-^
I stayed up one night playing poker with Tarot cards. I got a full house and 4 people died.
"Bub's are you an unethical quack?" - Homestar Runner
"Aww, now my heads not taped to the TV." - Strong Bad
I see you have the ring and I see that your Schwartz is as big as mine. -Dark Helmet
"The Claw decides who will go and who will stay."
"This is ludicris..." -Woody Toy Story
Old 10-07-2006, 12:27 PM
tmarsh tmarsh is offline
Does this work for a 4 cylinder?
