Old 04-22-2005, 12:58 PM
rshepherd1 rshepherd1 is offline
Oil pressure gauge going crazy - then car dies
My 96 suddenly just started dying while at a stop light etc... Wouldn't shake or stutter, just quietly died but starts right back up. Prior to it dying, the oil pressure guage starts jumping all around then goes right down to zero and truck dies. We have replaced just about everything to do with fuel system (that was the codes we were getting) and now when calling a local auto supply store, they told me it could be the oil sending unit, however, my mechanic says no.....any ideas??
Old 04-22-2005, 04:15 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Oil pressure gauge going crazy - then car dies
When was the last time you did a full tune-up? You said you did the fuel system, how about the ignition system? Plugs, wires, rotor, Dist cap, etc. Oil Sending units are usually pretty cheap to replace but they won't cause sputtering and dying. Start with the basic tune-up then report back.
Old 04-22-2005, 07:26 PM
blazee's Avatar
blazee blazee is offline
Problem?
I would suspect the oil pressure sending unit. If the oil pressure drops below 4psi the oil pressure switch will kill the power to the fuel pump causing the engine to die.
Old 04-22-2005, 08:16 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
The oil pressure was going crazy because you engine was going crazy.
The engine rpms govern the oil pressure.
You should do a complete tuneup.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-22-2005, 08:21 PM
blazee's Avatar
Problem?
Where does he say anything about the engine going crazy. He said the gauge goes crazy and then the engine dies. It doesn't shake or studder.
Old 04-22-2005, 08:30 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Oil pressure gauge going crazy - then car dies
All I was saying is that the oil pressure is tied into the engine rpms so when your engine dies, the pressure will drop as well.
I would take a look at the alternator because it could be failing.
Old 04-25-2005, 08:12 AM
Full Tune-up done in November 2004 do you think we need to do another??
Old 04-25-2005, 08:39 AM
Big Tall Dumb Ass
Re: Re: Re: Oil pressure gauge going crazy - then car dies
Ironically, I just had the same problem with my 93 Blazer over the week end. My daughter was driving down the Freeway at 60 MPH when the engine just died, and to make a long story short, the engine would restart after it cooled for 10-15 minutes. The oil pressure had nothing to do with anything. When I finally got it home, it would idle until it just about got up to normal operating temp and die just as if someone turned off the key. No spitting, sputtering or shaking, it just died while idling in my driveway.
My problem was the ignition module in the distributor. I replaced it and all is fine. The Boys at AutoZone tried hard to convince me that ignition modules either work or they don't, and normally do not restart after cooling, but I proved it to them when I took the old ignition module in and had them bench test it. It was bad and then had them bench test the new replacement as a precaution and it tested good.
Old 04-25-2005, 12:33 PM
BlazerLT's Avatar
AF -Advisor
What did this tuneup include?
Old 04-26-2005, 07:37 AM
Re: Re: Re: Re: Oil pressure gauge going crazy - then car dies
Router and cap, spark plugs and wires, fuel filter (has been replaced a second time since then), I think that's it, I would have to find all of my receipts to verify.
