Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 04-22-2005, 11:54 AM
colby1 colby1 is offline
crank shaft sensor
I have a 96 neon crankshaft sensor went out on it and the car would not start bought a new one and car ran fine for 2 months (2,500miles) it started loosing the high rpm pick up from the crank sensor replaced it again and it was fine for about another month now once again at higher rpm it looses signal it starts at 3500 rpm and and gets worse as rpms pick up I have changed the sensor one more time but this time it did not fix the problem I checked all connections batter,computer,wire harness,plugs,wires it pulls a code intermittent loss of crank or cam shaft sensor both are new is this a pcm problem not pulling signals or?
if any one has had this problem please help. thanks
Old 04-22-2005, 07:16 PM
1thunder 1thunder is offline
Re: crank shaft sensor
check the wiring by the trans bracket and also check wiring under pdc {fuse box} under hood and check wiring under big connector by the master cylinder somewhere it is shorting and these are the most common places
Old 04-25-2005, 02:33 PM
Thanks I used electronic cleaner and grease on all and any plug or conector I could find it seems to have fixed it but only time will tell
Old 08-05-2005, 03:44 PM
bhshoot bhshoot is offline
similar problem with a 92 bonneville
i was having the same problem. Seemed one of the ignition wires was breaking down when it would get above 4000 rpm. New wire no more problems.
Old 08-05-2005, 07:32 PM
palindromelol palindromelol is offline
What make you think the crank sensor is and has been the problem?
