Old 04-22-2005, 11:13 AM
rwebb001 rwebb001 is offline
2 Cooling Fans Running At Same Time?
I am overheating right now on my 5.7 TPI Iroc and was looking at band aiding the problem for now by placing a jumper on the two relays for the fans so they will both run when the ignition is on.
Would there be a problem doing this? I didn't know if the alternator was able to handle this on a full time basis.
One fan is not keeping it cool enough.
Old 04-22-2005, 12:02 PM
Link85x Link85x is offline
Re: 2 Cooling Fans Running At Same Time?
What the hell is going on? Was this common on all 3rd gens? Right now i am doing the same exact thing. I haven't got a chance to hook my second fan on the passenger side, but the one on the drivers side is hot wired to an existing wire connected to the fan system in the car. I'm also afraid to hook up he second one cuz the alternaor might not be able to handle it. So whenever i turn my fan on a low speed, my cooling fans are running fullblast and it works! The only problem when i turn the fan on high speed, my cooling fan runs at the lowest speed, so it kinda backwards. Hope this helps.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 04-22-2005, 07:27 PM
You have a nice car! It is the same as mine! Color and all. Mine doesn't have the T's though. I have an '87 Iroc 5.7 TPI auto tranny, no power accessories at all! I thought all Irocs had power options? It's like mine is a plain Jane with no buttons or whistles.
I know it is the real deal, done checked that out.
Fans......I didn't know there were two speeds on the fans. I have one fan running so it must be running slow speed. I haven't had the nerve to run the second one full time.
Old 04-23-2005, 12:48 AM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
i as well overheat, into the 210-220 range. im going to be riggin up dual electric fans one on each side of the radiator. and ill put them to switches inside the cabin but camaros are notorius from what ive seen. for that crap
Old 04-23-2005, 08:49 AM
Morley Morley is offline
That isn't over heating, that is the normal operating temperature for these engines. The fans are programmed to turn on at 224-226 degrees. Also, I doubt your gauge is telling you the actual temperature, they aren't that accurate.
Old 04-23-2005, 10:47 PM
yeah....no its right, i got autometer guages, still id love to run in the 180 range,just a personal preferance i guess
