Old 04-22-2005, 10:47 AM
UWCguy UWCguy is offline
Windshield wiper problem 1994 Silvarado
Sometimes they work and sometimes they don't. I've heard of other people having this problem. How does a guy fix it?
Old 04-22-2005, 11:03 AM
abaird abaird is offline
Re: Windshield wiper problem 1994 Silvarado
I had to replace the wiper motor on mine. It was $60.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 04-22-2005, 01:00 PM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
Yup wiper motor...my best friends sucked fat wang...replaced the motor...good as new.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 04-22-2005, 01:57 PM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
There was a safety recall on the wiper motor . I think that your '94 is in the group. CAll the dealer and give your vin. Should be a free replacement. I dont remember if they replace the whole motor assy, or just the board. The problem is the solder joints on the wiper motor board crack and come apart from the board. I had that same problem with mine but my truck is a '92 and it was not covered. So i took the board out, resoldered the joints and it works fine now.
Old 04-23-2005, 02:28 AM
roadrunner_70 roadrunner_70 is offline
Send a message via Yahoo to roadrunner_70
If you can buy a new motor for $60, then by all means. However, your problem may be as simple as the circuit board that is attached to your wiper motor. These are replaceable and are less expensive. You might even be able to fix it yourself. Over time the solder joints can break where the connector meets the board.
Old 05-03-2005, 10:34 AM
MyTOY's Avatar
MyTOY MyTOY is offline
just started having prob. myself after seeing these discussions
for so long. A couple days ago during rain, the wipers stopped
in up position. Kind of scary when you're with your kid and you
can't see the road. Also noticed my mist doesn't work now.
I've seen some detailed instructions on this seemingly easy job.
I going to give it a shot after work today. (resoldering circuit card)
Old 05-03-2005, 11:54 AM
Riche Riche is offline
it is not hard... pull the black cover off, the board pulls out. you will be able to see the bad solder joints.(usually a small black crack in the solder) It is ussually just the main solder joints were the wiring harness plug is.
Old 05-03-2005, 04:51 PM
Had a coworker experience the same in his '98 Silverado. We took the board out, and noticed a crack in one of the solder joints. The board also has two contact "brushes" that run along the rotating part of the motor. There was alot of grease build up on the parts, so he cleaned that off, soldered the suspect joint, and "lightly" pushed the brushes out for a better contact. He hasn't had a problem since. The brass contacts on the brushes were worn unevenly, with one worn down a fair bit, which, in time is going to require a new board, unless you can fabricate something in it's place. An electrical contact cleaner sprayed over the board should take the greasey residue off.
Old 05-03-2005, 05:06 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
My trucks had the intermitant wiper problem and all it ended up being was a bad ground. To check for this take a screw driver and touch it to the wiper motor case and the other to a nearby bolt and then turn the wipers on. Mine was fixed with a 6" piece of wire.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 05-04-2005, 10:27 AM
MyTOY's Avatar
I laid some new solder down. I guess I'll just have to wait to see if it's fixed.
I'll keep the ground wire issue in mind. I did see those 2 contacts and
wiped them off a bit but there was so much grease around, I assumed
they must need or be OK with it. The first thing I noticed was a reddish
shallac type stuff covering about half the card looking like a leak or
something that didn't belong.
