Old 04-22-2005, 10:08 AM
tcfco2005 tcfco2005 is offline
rear end swap
when swaping a rearend on a 91 rs to one from a 4th gen is there a certain 4th gen year i should get. wich ones have the better gears. and most of all does the swap go strait in or do i have to get any conversion parts.
thanks
Old 04-22-2005, 10:27 AM
Link85x Link85x is offline
Re: rear end swap
thanks
Tcfco, i'm gonna do the samething eventually. I hate drum brakes. I think all my springs came loose back there. I would like to know about the 4th gen swap too. I believe you would have to change the master cylinder, and you're gonna have to add abs too. I'm not too sure.... someone help us out!!
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 04-22-2005, 10:31 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Why waste the time and money taking out one shitty 7.5 ten bolt and replacing it with another shitty 7.5 10 bolt.
Other than that, you would need a new master cylinder but, I am not sure if you would need the the abs unit
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 04-22-2005, 10:38 AM
Re: rear end swap
Hyspi87, wouldn't a 4th gen 10bolt be better than a 3rd gen? Didn't most of them come with better gearing and discs brakes? I know mine has 2.73 and drums. Are the 700r4s from 85-92 almost identical to 4le60(is that it? i don't know) from the 4th gens?
Old 04-22-2005, 10:42 AM
Re: rear end swap
i have a 91 rs with a 700-r4 and im pretty sure i have the same rearend set up as you link. and hypsi what rear end would be better then.
1991 RS
305 T.B.I.
700-R4
Old 04-22-2005, 10:51 AM
Hypsi87's Avatar
a 12 bolt, ford nine inch blah blah blah
moser, strange engineering people like that make them
3rd gen, 4th gen it does not matter. It is still a POS 10 bolt with the small 7.5 inch ring gear. Sure the carriers might be different. If you guys are serouis about making power, or running some sticky tires. you will blow that rearend up in a matter of weeks.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 04-22-2005, 10:54 AM
Re: rear end swap
Naw don't want too much power just enought to be able to run low 13's in the future(way into the future), could we just beef up the 10 bolt to handle i say 300rwhp? Btw hyspi, what rearend do you have in the GN?
Old 04-22-2005, 10:59 AM
Hypsi87's Avatar
Re: Re: rear end swap
if you want the power to run low 13's you will break that rearend. (assuming you are going to be on a set of sticky tires)
The GN has a 10 bolt in it but it is the beefier 8.5 inch ring gear 10 bolt. They are 12 bolts in 10 bolt colthing. they will hadle crazy power with no problem
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 04-22-2005, 11:02 AM
Re: Re: Re: rear end swap
Could you put a 8.5 inch ring gear in our 10 bolts?
Old 04-22-2005, 11:07 AM
Hypsi87's Avatar
Re: Re: Re: Re: rear end swap
nope the 8.5 ten bolt has an entirely different carrier.
Also to my knolwedge, no one makes one to go into the F-bodies.
You could go with the nine bolt aussie rearend out of the IROCS and TTA's and GTA's
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 04-22-2005, 11:52 AM
Re: Re: Re: Re: Re: rear end swap
I think i'll just suck it up and hope in the future that i can run into one of those nine bolts. I saw a couple on ebay for a couple of hundred dollars, but they are to far away to deliver to my area. Junkyards i've gone too only have regular maros' and birds'. I'll keep a look out for one.
So tcfco, i think we both should aim to try and aquire one of these nine bolts, cuz i also think they will be a direct fit. Correct me if im wrong.
Old 04-22-2005, 12:55 PM
Re: rear end swap
how much power can those 9 bolts handle.
1991 RS
305 T.B.I.
700-R4
Old 04-22-2005, 01:05 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: rear end swap
If you run the 12 bolt or 9 inch keep in mind it'll rob more power
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 04-22-2005, 01:21 PM
What do you mean by rob more power? Weren't those 9 bolt from the 350 irocs and ta's weren't better than the crapola i have now. If your talking about losing out on top end power, i read an article from an old motor trend magazine on the web about the top 10 fastest cars test (in 1988)iroc and Gta were in it. Iroc top out at 147, while the Ta top out at 141.
Old 04-22-2005, 01:50 PM
Re: rear end swap
9 INCH not 9 BOLT, i dont know much abotu the 9 bolt. But the 12 bolt or ford 9 inch are bigger than the 10 bolts, and heavier. More mass to rotate = more power los to the wheels. 4th gen 10 bolts can hold up to I think it's around 400 horses... get one out of an LT1 for your cars, and make sure it's one without traction control.
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
