Old 04-22-2005, 07:22 AM
doomstress doomstress is offline
Send a message via AIM to doomstress
Factory Radio problems?
I posted this on the Stratus forum but no reply...
I just bought a '95 Stratus. When I took it home, I noticed the radio wasn't working. I didn't think it was a big deal, I'd just replace it with an aftermarket head unit. Then the next time I drove the car, the radio worked. It worked for 3 more times of starting the car, and then stopped working again. Sometimes the clock will show up, sometimes I get nothing at all. Once or twice I got just two lines. I don't know if it's the fuse, or a short, maybe? I don't know much about wiring and all that. My brother knows some, but he lives an hour away. All I know is that it's confusing me, and am I going to have the same problem if I put an aftermarket head unit in? If it's a simple problem to fix, Id rather not waste the money on another head unit.
Thanks in advance.
Old 04-22-2005, 11:52 AM
germanyt germanyt is offline
Re: Factory Radio problems?
i think the problem might just be a loose wire in the harness. perhaps the power from the head unit or maybe a loose ground and the normal vibration of the car and driving could be shaking it around causing it to lose contact. check all your connections. pull on them gently and make sure that they are all snug. make sure to check the ground wire too. wherever it may be connected, it varies from make to make.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 04-22-2005, 05:11 PM
Thanks, I'll have to try that... If I can figure out how to get the damn thing out
