Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-21-2005, 11:38 PM
CanadianRanger CanadianRanger is offline
head gasket leak
I have an interesting problem ( at least the mechanic thinks so). It seems that a consistent misfire caused by a faulty ignition module caused fuel to build up in the sixth cylinder( or at least the one closest to the rad). Then it would detonate causing overpressure or something like that. this caused either the head or the head gasket to crack or leak someho. anyone ever heard of this problem before?
can someone also tell me for sure which cylinder is the sixth cylinder.
Vehicle
1994 rodeo-3.2l v6 sohc auto trans.
Thanks
Old 04-25-2005, 06:44 AM
superfret78 superfret78 is offline
I think your #6 cylinder is in the back on the driver's side. The detonation problem is a pretty common cause of head gasket failure in a lot of cars. Make sure you've got the right spark plugs and check your EGR as well. The faulty ignition module is just one of several things that could cause detonation that would lead to a blown head gasket.
Old 04-27-2005, 11:19 PM
tried a new module in her and she runs right, cept for the head gasket. does anyone know what the part number is for this module,and is the one outa the gm 3.1s the same, the mechanic thinks it may be, but i need to know for sure. thanks
