Old 04-21-2005, 11:20 PM
scortfan1 scortfan1 is offline
97 escort probs
HI!
I'm a new member to this forum, but real glad to have joined! I have been restoring and taking care of my 97 ford escort LX for about one year now. I have done all the work on this thing ever since I bought it for 100 dollars! The girl I bought it from crashed it into a mailbox concreted about 2 feet in the ground going about 60 m.p.h! She said she was going to DRIVE IT to the junkyard; I seen it and bought it that day.
Anyways other than a broken window, bashed driver fender, and a cat hair infested interior it was perfect. All of these I have fixed and replaced, but I've run into some problems!
This has a OHC 2.0 with a manual transmission, and I cannot find out where the trans fill hole is at. I found the drain but no filler, also I cannot find out where the fuel filter is at either. Can you guys/girls help me please!
Old 04-22-2005, 06:58 AM
Click23 Click23 is offline
Re: 97 escort probs
Go over to http://www.alldatadiy.com. For 25$ you can get the same info tons of independent mechanics have. You can click on the demo to see what you get.
Old 04-23-2005, 05:09 PM
Thanks anyway but I'm not gonna sign up for anything. You never know what your gonna get yourself into ya know.
It's just a four banger, and yes I probably will lose. It's just kicks for me, but if I win expect a shit load of GLOATING !
Old 04-23-2005, 05:31 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 97 escort probs
Just so you know you can search all posts on this board and when I did I found this info it should help ya.(not my reply but of others)
"If you have a manual transmission you need to locate the speed sensor, speedometer gear, on the transmission. You can find this by following the speedometer cable. Disconnect the electrical connection to the sensor. Clean the area around the sensor and gently pry it out. Check the fluid level at the speed sensor. If it is low, place a funnel in the sensor hole and fill to the full level. Reinstall the cable.
remove the electrical connection, and get a slip joint pliers or normal pliers, and gently rock the sensor back and forth all directions to try to loosen it up and slowly work it out, its what I had to do. but my buddy had the same problem before and he broke his, I think he said you could get a replacement senor from ford for like 35 to 40 bucks, but I never checked on that."
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 04-24-2005, 04:06 PM
Thank you that does help me out. I can find that probably I just gotta wait for it too stop snowing here in michigan!
Old 04-26-2005, 12:30 PM
Re: 97 escort probs
No prob, just thought since you quite a bit of work to do on it you might of wanted to check it out. I know if I hadn’t of looked at it before I changed the half shafts in mine I would have been in a world of trouble. Turns out you cant pull both at the same time or some splines or something in the tranny will collapse
Old 05-04-2005, 06:59 PM
toolman11 toolman11 is offline
Fuel filter is behind the motor on the firewall, next to the power brake booster (black round drum behind brake fluid reservoir). It's tricky to snake your arm in to reach the hose clips, especially the bottom one.
I raise the car and get to the bottom one from underneath. Use a long flat screwdriver to pull the clips.
Old 05-06-2005, 12:10 AM
mike t. mike t. is offline
Talking Re: 97 escort probs
in oder to fill ur trans with fluid u have to remove the speed sensor. the trans u have is called a matance free transmission
Old 05-06-2005, 04:02 PM
chevyn0va1's Avatar
Re: 97 escort probs
be sure your new filter has replacement i have found the plastic clip either brake apart or you loose them.
