Go Back   Automotive Forums Car Chat > Fabrication & Tools > Other
Other Other fabricating topics.
Old 04-21-2005, 11:02 PM
Lonely SOl Lonely SOl is offline
Question Whats the best way to paint the interior panels?
HI I want to paint my interior panels same color as the car. I dont want to die because I want to have smooth and shiny finish just like the outside. I have tried to use resin on plastic dash and that wont stick, tried bondo, but it dont stick either. What is the best way to do that. Also how do people make fiberglass dash?
Old 04-22-2005, 12:02 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Whats the best way to paint the interior panels?
scratch up the dash just like you would a car, with some sandpaper. Also you need to take off all the protective shit on the dash like mothers and armor-all with a wax and grease remover. use a fiberglass filler and basically bondo the dash. sand it down until you have a very thin layer over the dash so you get your smoothness. prep it like a normal car and paint away.
95 Talon TSI AWD
97 Eclipse GST
Old 04-22-2005, 07:23 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
You need to use some plastic degreasers. Bondo body filler doesnt stick to plastic anyway.
-Mike
Old 04-22-2005, 08:30 PM
evansdad evansdad is offline
Send a message via Yahoo to evansdad
so dont use the bondo? how do you get the smooth look? can i get the plastic degreaser at any auto parts store?
Old 04-22-2005, 09:24 PM
yea I tried the fiberglass filler but it doesnt stick to it, it comes off it. do they make any special bondo to stick on it. Are you talking about short strand fiberglass, I tried that i also tried resin. WHat else can I try, I am basically out of suggestions
Old 04-22-2005, 09:31 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
the best way to do it is to sand the texture off of the plastic. This is a bitch to do because the plastic gets fuzzy. You can sand it by hand with 80 grit to remove all the texture then wetsand with 200g then 400g and it removes most all of the "fuzz". You need to follow that by an adhersion promotor then a good high-build primer. After you have a good build of primer you'll need to hit it with 200g and 400g again. After that paint as you would anything else.
Old 04-22-2005, 09:34 PM
sounds good, is is hard as hell to get all the scratches off the dash and also what about the vinyl covering it. DO I take that off and expose bare plastic. I am just afraid to rip the vinyl off without being sure it will work thats why I havent ripped it off yet. But so, thsi would work ur saying?
Old 04-22-2005, 09:50 PM
Forunn Daberator
well vinyl is a differnt story, this method as discribed doesnt work word for word for vinyl covered plastics. There is a few things your going to encounter. 1) your going to have lots and lots of tiny holes to deal with, this is because all the factory vinyl is vac formed onto the panel. These holes are small enough that they can be filled in with a body filler without any problems. 2) The panels were made to fit together with the vinyl on them so if you assemble them together without the vinyl there going to be smaller and may have small gaps in them, this can be overcame most of the time by carefull mounting and adjusting and such, and isnt allways an issue depending on how your stuff is made and put together. 3) Irregularities such as the plastic going from smooth to textured, granted your going to be sanding it but I just dont want you to strip it and be shocked by what you see. Basically the process is the same just with a few indefinate added steps.
Striping the vinyl from the stuff is pretty easy also, most of the time you can take a putty knife and get it loose around all the edges and scrape the entire thing off in one piece. Once the vinyl comes off its an ugly sight, theres padding and god awful colors of glue. Now put on your respirator and bring out the acetone and scuff pad (scotch brite pad). It takes it off pretty easy with a little work. Even though your going to be sanding it, I allways like to start on something thats clean. Make sure to do this in a ventilated area, and wear gloves.
Old 04-22-2005, 09:54 PM
okay sounds good so far so after I get all the vinyl and glue off, will the bondo stick to it to make the thing smooth or just prime it and fill it up with primer
Old 04-22-2005, 10:04 PM
Forunn Daberator
refer to post #6
Old 04-22-2005, 10:06 PM
so it doesnt require bondo at all then
Old 04-22-2005, 10:28 PM
Forunn Daberator
nope
Old 04-22-2005, 10:50 PM
so I guess let me get this straight so I dont screw it up. First I take the vinyl off then take all the glue off with acetone then after all of the glue is off then sand everything it off until it is smooth and (woiuld it be better to add bondo) then with 400 smooth it and then 600 and then prime it.
Old 04-23-2005, 11:38 AM
Forunn Daberator
Get bondo off your brain! Yes do that but sand with 200 and 400 to smooth it.
Old 04-23-2005, 04:48 PM
lol iight man thanks for helping I really appreciate it
