Oil Question
Today I was over at my friends house and we were changing the oil on his 93 Maro. He was opening the new oil bottle and dropped the whole foil seal into that bottle. So we put a piece of screen over the bottle and poured the oil in. The screen didn't catch the foil seal. How bad is this going to be on his engine. Shouldn't the foil heat up and melt?
White 07 STI, Bone stock for now |
it might block the oil, but I dont know, i'd try to get it out as quickly as possible though.
what makes u think u didnt catch it, cuz man thats a pretty big foil seal am i right??
Re: Oil Question
some screen huh?
the foil seal should not hurt the car. it will not melt... take another seal and put it in a pot of water and put that into your oven and heat it to about 400 degrees. it should fold up into a little ball. it won't get into the oiling system because of the filter on the oil pickup and the oil filter itself. But you should take your valve cover off and pull it out if it's still on the head, which it probably is. Maybe over an extended period of time it decomposes due to heat?? who knows?!? take it out if you can.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Re: Oil Question
instantkevin- I am kind of confused on your post, you say it should get stuck in the oil filter but then you said he should take off the valve covers? Hopefully it will just get caught in the filter.
Re: Re: Oil Question
Re: Oil Question
i dropped a very little piece of this into my dads impala when i was changing oil, and it has had no problems. (i forgot to mention it to my dad too.. woops)
