Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-21-2005, 09:34 PM
Zandam Zandam is offline
Bright Headlights won't work
When I change from dim to bright on my headlights, the lights go out!
This is a 94 Caprice Classic that was a state trooper vehicle.
IS this a cop thing or do I have a serious problem??
Thanks, Zandam
Old 04-22-2005, 11:34 AM
LeafsBlow29 LeafsBlow29 is offline
shouldnt be a cop thing...one of my highbeams is out, i just havent changed the bulb yet, maybe both of yours are out so try changing the bulb
Old 04-22-2005, 04:41 PM
HLandin's Avatar
HLandin HLandin is offline
My guess is it might be the headlight dimmer switch. Used to have the problem that sometimes when I changed from low beams to high beams, the lights would cut off like you said. Replaced the dimmer switch and no problems since.
Old 04-22-2005, 05:37 PM
Thanks for the ideas. I have replaced the bulb and no change. It sound like the dimmer switch is the right answer.
I have not changed one on the Caprice, will I run into problems with the air bag. I am assuming the dimmer switch is included with the turn signal, speed control etc. on the steering colum.
Thanks, again
Old 04-22-2005, 07:25 PM
CD Smalley CD Smalley is offline
Re: Bright Headlights won't work
There was probably a wig-wag unit installed. Look under the hood for a green wire running to the headlights. One of them is cut....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 04-23-2005, 01:51 PM
Re: Re: Bright Headlights won't work
i still remember all of the wires i pulled out of mine, piles and piles of wires...
