Old 04-21-2005, 08:19 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
brake lights not working ?
They used to work, now I havent drivin the car in over a year.....I went to drive it today and they didnt work, I checked all fuses, all the wiring that I could think of, aswell as the switch on the end of the brake pedal.....The bulbs do work, and the taillight housing is not faulty.....where is the taillight relay located ?....I found the rear defroster, and the Turn Signal relays...but no brake assembly one.
Has anyone ever encountered any problems like this.
-Brad
89 DX: LS Powered
88 CX: Project ZC
Old 04-21-2005, 08:55 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: brake lights not working ?
i did, i jus went to junkyard and swapped out the wire harnesses - the wiring was just worn out i guess after so many years
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 04-21-2005, 09:47 PM
I figured it out....so no more need to provide tips....It was the Horn wiring....either way they must run the same wiring circuit.
-Brad
89 DX: LS Powered
88 CX: Project ZC
