Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-21-2005, 07:37 PM
lifelongslacker lifelongslacker is offline
Arrow Check Engine 440
I have a 97 Rodeo 3.2L V6. My check engine light has been on and off for the last week with error code 440 (Evaperative Emmission Control System Malfunction). I looked at the O2 sensor and I have a small oil leak above the sensor. The O2 sensor is soaked in oil on the outside. Anone got any Ideas if this is the problem? (I didn't think the oil would affect the sensor on the inside of the pipe.
Old 04-21-2005, 07:54 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
P0440 isn't associated with any of the O2 sensors.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 04-21-2005, 10:29 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Check Engine 440
http://isuzufaq.ibctech.ca/#faq2a
tighten your gas cap.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-23-2005, 07:49 AM
The gas cap is all the way on, but it is one of thoes aftermarket locking caps. I will try to find where I put the factory one
Old 04-23-2005, 11:22 AM
rodeo02 rodeo02 is offline
Re: Re: Check Engine 440
Originally Posted by lifelongslacker
The gas cap is all the way on.......
Doesn't matter. If the check valve in the cap does not seat & the pressure bleeds of the gas tank over time, you will get EVAP system codes. You can 'usually' tell if you can smell a gasoline odor around the fuel filler area.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
