Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-21-2005, 07:21 PM
GForce957's Avatar
GForce957 GForce957 is offline
trunk rattle from bass
Hey guys, i have subs in the trunk and whenever i have the volume too high the trunk rattles like no ones business. Any ideas on what to do to stop that?
Old 04-21-2005, 10:05 PM
mysatilac's Avatar
mysatilac mysatilac is offline
Might be your license plate or license plate light covers (mine rattle, not my trunk), but you'd know better than me for your car...
Use sound deadener, like dynamat
Dynamat Trunk Kit $78
Dynamat License Plate Kit $8
It should quite down the rattle completely, but is very pricey
Might Wanna do a search for sound deadener
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 04-21-2005, 10:15 PM
GForce957's Avatar
Re: trunk rattle from bass
thanks man
Old 04-22-2005, 10:42 AM
Tylerc161 Tylerc161 is offline
Send a message via AIM to Tylerc161
or, in my case.. the little black plastic piece that holds the lights that shine on your license plate is never secured. its just wedged in there. i took mine all the way out, put cocking on it, and stuck it back in. nomore rattling
Old 04-22-2005, 12:30 PM
mysatilac's Avatar
It is very annoying,
I just tried the caulking to see if it helps, - it didn't, my L/P rattles up against the trunk, or the trunk rattles out against the plate... I'm gonna put a foam pad under the plate...
To see if this is also your problem GForce, while your system is on, go to your trunk and hold the covers, LP, and trunk in place to locate where the rattle is,
Old 05-02-2005, 10:10 PM
sneyeper sneyeper is offline
Send a message via Yahoo to sneyeper
It is the internals to the trunk itself ... ie:the rods and things you see if you look into the spacing in the trunk ... sound deadening will help greatly ... mine rattled with no plate on and the plastic red piece removed off the outside until I figured out it was the internals ... sound deadening the complete trunk was required to remove almost all of the rattle
Old 05-02-2005, 10:17 PM
mysatilac's Avatar
Re: Re: trunk rattle from bass
I know what my problem is, depends on how your subs are facing, and the amount of power they generate, my internals are solid enough, I checked by pressing down on the plate, the rattle stopped
Old 05-04-2005, 02:27 AM
Nixa96SaturnSC2 Nixa96SaturnSC2 is offline
Send a message via AIM to Nixa96SaturnSC2
I had subs in my trunk for quite a while and it rattled everything from the internals of the trunk, to my rear tail lights, liscense plate, and spoiler.... the spoiler vibrated so much i was just waiting for it to jump off of my trunk lid going down the highway. I just tried to make sure everything was tightened down as much as possible to try to keep it from moving at all.... didn't help a great deal, but hey, i tried
Old 05-04-2005, 10:45 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Turn down the music crazy kids! haha
Travis
Old 05-04-2005, 11:16 PM
mysatilac's Avatar
crazy KIDS?!?
Your about my brothers age, 21,
You should have a system yourself,
Or did I detect some sarcasm there,
Turn It UP! I'm young enough that I can't hear it anymore,
Old 12-16-2005, 12:59 AM
TKTSCR TKTSCR is offline
first screw everything down tight. i put a rag and tied it around the torsion bars that go accross the trunk. you cant see the rag cause it high. than move the latch down just enough to make a more firm seal. you can add the matts on the trunk and or every place else as you know everything sounds like its about to fall off due to fastners used all over to hold things down. great for wieght not for dum..dd..d..dumm dumm thump!!!!! hope this helps..
Old 12-16-2005, 12:41 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
it can be many things. like someone said the license plate area is one place, typical of license plates to rattle. also saturns have a removable plastic piece on the back of the trunk lid, dohc have a reflector type while the sohc have a painted one). either one of those things could cause it, but for my car it was the license plate rattle off the trunk lid(i no longer have subs). it could also be things on the inside too. but dont run the car just turn it on and turn on the subs, and go in back and see if you can find where its coming from.
Old 12-16-2005, 02:10 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
doesn't anyone look at the dates on these threads? jeez..................
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 12-16-2005, 02:13 PM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
Locations where you will find this: Trunk lid, dynamat helps with the points where the skin is not tight against the frame from spot welding.
rear deck where your speakers are this panel vibrates on top of the frame it sits on.
behind the fold down seats, the small lip also vibrates as well
license plate, vibrates horribly as well, dynamat plate holder works wonders
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 12-20-2005, 11:04 AM
damn i just noticed the date when this started.
