Old 04-21-2005, 06:40 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Angry Damn Valve Stem Caps! Please help
Guys, I've gotten myself into one hell of a predicament.
Both of my rear valve stem caps are stuck to beat the band. I cannot break those little buggers loose to save my life. I don't need to right now - my tires are inflated fine, but sometime when I'm going to want to remove them, I won't be able to. I've tried using wrenches / pliers, ect., but I always end up just twisting the valve stem itself, and if I hold it while I turn the top, the rubber just twists anyways, and I'm afraid I might split it. Any suggestions? Thanks a ton
Ridenour
Old 04-21-2005, 06:57 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Damn Valve Stem Caps! Please help
Are they plastic or metal? Try heating them up with a lighter or a propane torch with a very low flame before turning. Just a bit of heat should be all thats required.
Old 04-21-2005, 07:03 PM
Ridenour's Avatar
GranddAmnit
Thanks - They're metal with a rubber ring inside. Are you sure it won't melt the rubber inside or the rubbber on my valve stem?
Old 04-21-2005, 07:39 PM
MagicRat's Avatar
Re: Re: Damn Valve Stem Caps! Please help
Well, the idea is to use a very small amount of heat. Try a disposable lighter first.
Old 04-22-2005, 05:01 AM
Ridenour's Avatar
GranddAmnit
Ok thanks - I'll give it a go this weekend
Old 04-22-2005, 07:17 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Whenever I have a problem like this, I get out the Dremel tool and cut them off.
Old 04-22-2005, 10:52 AM
public's Avatar
public public is offline
Yep, works every time. Just make sure you cut the valve cap straight up the side. It will almost fall off.
Yes, I am retarded.
Old 04-23-2005, 03:03 PM
Omega_5 Omega_5 is offline
Call me primative... but i like to use the hammer first....jk
Tyler L
Thank god winter is over.... time to hit the track!!!
Why do some people hate me? I'm not bias... I just hate rice...
(Except chicken fried rice that is....yum yum)
