Old 04-21-2005, 07:06 PM
Trailblazing Trailblazing is offline
05 Trailblazer Factory Speaker Size
I Have An 05 LT Trailblazer With The Bose Sound System And Would Like To Up Grade But Don't Know What Size Speakers I Have In The Blazer. I Do Believe I Have 6 (3 Pair) Dash And 4 Doors. Thanks For Any Info Brian
Old 04-21-2005, 11:26 PM
tkeo tkeo is offline
door speakers
I've got an 04 non Bose and I replaced all the door speakers with 6-1/4" Infinities. I had to modify the plastic enclosure slightly because the mounting pattern was slightly different and the new speaker frame interfered with the housing in a couple of places but it was not difficult. I was told that you could fit 6-1/2" but from what I remember it would require more extensive modifications to the housing (fire up your Dremel!). The stock fronts were rated at 8 ohms each and the rear was 4 ohm each. The replacements are 8 ohm all the way around with no issues. I desolderd the connectors on the old speakers and used them on the new. Just check to make sure that you have the phasing (+/-)the same as the stockers.
Old 04-22-2005, 01:57 AM
ScarabEpic22 ScarabEpic22 is offline
I can't offer a direct response to your question, but I know at least in 02-03 TB with BOSE, there is an external amp in the trunk in the passenger side panel. Don't know what problems this will present, but I think it will be more difficult to swap out the speakers. Hope this helps a little.
Old 04-26-2005, 09:53 AM
ginzy ginzy is offline
Well sorry, but I wonder why would one change the speakers like bose system. I own 05 EXT LS, I got my stock speakers replaced by Audiobahn ACS2062 ( 6.5" 2 WAY, 200 WATTS MAX, 4OHMS). And also added a set of tweeters. pretty good ones from Pyramid TW27. It has Motorola driver in it & sound sharp n good (and cheap ) .You gotto open the front dash to install these in the right place under the factory grill. they sound gr8.....
Old 04-26-2005, 05:15 PM
other thing you might need to install interface (check Axxess GMOS-03 ) as you have bose system. cheers......
