Old 04-21-2005, 06:05 PM
4500 4500 is offline
Unhappy 7.3 glow plugs
I have a 97 f350 with 7.3 and the glow plugs will not work till i jump the soliniod for the glow plugs, no voltage getting to the soliniod at all,what do i check?
Old 04-21-2005, 07:42 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: 7.3 glow plugs
Have you checked your distributor? If so and all looks good, i might tell you to check your plug wires. Let me know.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 04-22-2005, 12:43 AM
ModMech's Avatar
ModMech ModMech is offline
Re: Re: 7.3 glow plugs
ROFLMAO!!!!!
Um it is a DIESEL, no sparkplugs OR wires.....
If there is no power to the solenoid (relay) big wire, then you have blown a maxi-fuse, if there is no power to the small wire, you have blown a glow-plug relay fuse. The relay is grounded (small wire) by the ECM when it sees the coolant/oil temp below a certain threashold. The glowplugs are NORMALLY on for a few seconds even in 90*F weather, unless the engine is up to operating temp, before and during start-up.
Check for power to the one small terminal (key on), and one large terminal (battery power). If they are both good, the ECM is not grounding the relay when it should (I have never seen this failure mode).
Old 04-22-2005, 06:57 AM
Re: Re: Re: 7.3 glow plugs
Originally Posted by ModMech
ROFLMAO!!!!!
Thanks for your help
I have power to the big wire but not to the small wire,
Old 04-22-2005, 10:24 AM
ModMech's Avatar
Re: 7.3 glow plugs
Sounds like a fuse, should be in the "under hood" fuse box near the left hood hinge..... but I don't remember for sure.
Old 04-22-2005, 01:25 PM
Smile Re: Re: 7.3 glow plugs
thanks, I will go check it now.
Old 04-22-2005, 02:04 PM
Re: 7.3 glow plugs
oh my fault... dont mind me i obviously wasnt thinking.
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 04-23-2005, 10:34 PM
fuse all look good
