Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-21-2005, 04:47 PM
zdude zdude is offline
Send a message via Yahoo to zdude
Brake Bleeding Screw
Broke both the front ones off. thats after i sprayed them down with WD40. i cant get them out and have basically mangled the stubs with the vice grips. my guess is to just get two new calipers. but i dont think i can afford that. just checked a random online store, 40 bucks a piece, then it says plus the core. 30 bucks. usually sending the core in makes it cheaper because they can recycle it. like if i got a radiator, 200 bucks, plus sending the core in, -75 bucks. im not going to pay 140 bucks for calipers. if anyone has two front calipers for a 95 corolla that they no longer need. i am very interested in them. please contact me at the email provided below.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
89 240sx (sold then died)
85 735i (Died)
95 Corolla (Damn Deer)
94 Renault Espace (gave away lol)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 04-21-2005, 11:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Brake Bleeding Screw
If you can still grab them, try spraying them with penetrating oil. WD40 is not penetrating oil. Make sure you are turning them in the right direction. Try grabbing them with an easy-out.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-22-2005, 05:28 PM
well, i got this stuff from the local shop. i just said wd40 because i cant remember what its called. i actually got the new pads in. but right now the brakes are soft because i had to loosten the brake line screw to expand the caliper. the brakes are functional, but not full pressure. i need to find a way to bleed them. both screw heads for the bleeders are snapped off, stupid but it happened. if its the type that you can bleed any corner and get all the air out, i might be able to bleed the rear and go that route, otherwise ill have to get new calipers. but for now i dont have metal on metal. it was real bad, the gritty material from the pad was totally gone.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 04-23-2005, 01:56 PM
Brian R.'s Avatar
Resident Chemist
Buy an easy out and unscrew it using the hole. If you can insert an easy out in the hole, you can remove the plug.
Old 04-23-2005, 01:57 PM
Brian R.'s Avatar
Resident Chemist
Buy an easy out and unscrew the plug using the center hole after you spray it with penetrating oil. If you can insert an easy out in the hole, you can remove the plug.
