Old 04-21-2005, 04:28 PM
jlshondacrx90 jlshondacrx90 is offline
MSD SCI Ignition went bad, 1 week old
my msd ignition went bad the other day, did i hook something up wrong? positive and negative hooked up to SS coil, Old coil removed, power and ground were hooked up right.. was there anything else i needed to remove? or do you think it was just a defective ignition box?
Old 04-21-2005, 07:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: MSD SCI Ignition went bad, 1 week old
could be defective box. throw it away and jsut run the coil. thats all you need anyways
Team Lonely Drivers
Old 04-21-2005, 10:07 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
DAMN I WAS THINKING OF GETTING ONE OF THOSE, "THROW IT AWAY!!!!" THEY RUN LIKE $200 w/ rev limiter.
Old 04-21-2005, 11:21 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
call up msd, they have great customer service.
I used to have a problem with my 6a box squeeling at certain rpm called them, they said to send it in. They fixed it and sent it back.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 04-21-2005, 11:23 PM
BullShifter's Avatar
Re: Re: MSD SCI Ignition went bad, 1 week old
I use the SCI with rev and never had a problem, expect for a bad connection. Did you cut the wires needed for a 4 cylinder?
You can always send it into MSD.
Old 04-22-2005, 03:32 PM
i had it wired just like that diagram except for the ground was on the frame not the battery...would that matter?
Old 04-22-2005, 08:15 PM
as long as your grounding is good no. I also ground mine on the body, right where the resister box used to be. Call MSD and talk to their technical support.
Old 04-27-2005, 11:39 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
i have the same set up and (dont want to jix my self) have had no probs. Call them and they should take it back and replace or rebuild it.
Old 04-27-2005, 12:10 PM
CBURKE's Avatar
CBURKE CBURKE is offline
You don't need one anyway. The MSD coil is good enough. Hondas ignition is more then good enough to through what every you want at it.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-27-2005, 02:44 PM
smokeymicpoter56 smokeymicpoter56 is offline
msd is the shit send in the box and they well fix it and if honda was that good at what they do than we wouldn't want to upgrade. i work at a honda shop and all we do is build honda's and every car there we used either the sci msd or the digtal stuff and we always use on every car is the aem ems its the bomb.. soo theres what i think hope it helps and i felt my car pull harder win i put msd on my car
Old 04-28-2005, 01:28 AM
It's proven that a stock Honda ignition can support up to 250HP. The last thing you want on forced induction is a spark blown out, MSD sparks 6 or 8, i forget.
My igniton box also grounds to metal.
Old 04-28-2005, 07:33 PM
Sparsky Sparsky is offline
Not to Hi Jack the thread. But who has the best price on these MSD Ignitions?
http://www.cardomain.com/memberpage/765867
Old 04-28-2005, 08:09 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
you can find the lowest prices at walmart, right by the apc mufflers, the chevy altezzas, and the chrome spinner hubcaps!
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 04-29-2005, 05:55 PM
LOL... I guess I'll just stick to Summit Racing.
Old 04-30-2005, 08:00 AM
CBURKE's Avatar
Re: Re: Re: MSD SCI Ignition went bad, 1 week old
no, just don't wast your $
if you don't plan on makeing a big bad ass 300hp civic then don't bother. maybe get the plug wires and a cap, the exsternal coil is ok to. but there is no need for the MSD box!!!
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
