Old 04-21-2005, 03:30 PM
Sen Sen's Avatar
Sen Sen Sen Sen is offline
Knocking POS engine.
: swear:
I just finished spending about $2grand on repairs/mods to my truck and today I heard an oh so sweet knocking noise come from the engine. Needless to say, this caused me to come up with many new swear words. I have read some threads and will be flushing out the oil, this week.
I just wanted to ask if the oil flush doesn't help....What else can i do that wont bust the bank???
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Faster and louder than stock, but nonetheless a blazer!
Old 04-21-2005, 03:37 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Might not stop the knock but you can try Mobil1 5W-30. FOllow the flush directions as you have read in these posts, idle for 45 minutes then drain. Do not rev or race the engine. Stay away from Fram filters as everyone would say and buy a stant radiator cap. What was done in the shop to your truck?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 04-21-2005, 03:39 PM
Or should I say what did you do that cost 2 grand and was it knocking before? Or a slight knock?
K&N Air Filter
Old 04-21-2005, 03:59 PM
Sen Sen's Avatar
Re: Knocking POS engine.
no knock at all before, it started today?
$2 grand in Headgasket, headers, fuel pump, had the bumper/grill painted to match the body, new hub and wheel bearing, starter.
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-21-2005, 05:28 PM
Sen Sen's Avatar
Just wanted to show you guys the diffrence it made in the look.
Before::
[img][/img]
After::
[img][/img]
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-21-2005, 05:31 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What oil and filter are you using?
How is the oil pressure?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-21-2005, 05:45 PM
Sen Sen's Avatar
ac delco filter...
when I start up it runs normal, but after about 5min my oil pressure drops near zero.
As soon as I step on the gas it goes back up. Its kinda hard to tell because the oil pressure gauge is crap it has markers at 0,275,500
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-21-2005, 07:39 PM
BlazerLT's Avatar
AF -Advisor
So if you raise the rpms, the knocking goes away?
Old 04-21-2005, 08:11 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
When was engine work done to it, how long ago? Does oil pressure come back up right away to normal as soon as you step on the gas? Something might have gotten stuck somewhere causing either a restriction, or maybe the oil pressure bleed off valve on the oil pump can be stuck open exhausting to much oil at idle. Sounds possible since something like a piece of gasket material or debreis can easily get into the engine when the head gasket was done.
Old 04-21-2005, 08:20 PM
Sen Sen's Avatar
Re: Re: Knocking POS engine.
no, it gets louder and faster as the rpms go up!
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-21-2005, 08:22 PM
Sen Sen's Avatar
The repairs were done 2-3 weeks ago, I haven't heard or had any problems with it till today! I can honestly say it ran perfect before the noise started. The oil pressure does go up as soon as i step on the gas.
Thanks for your help in advance!!
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-21-2005, 09:45 PM
BlazerLT's Avatar
AF -Advisor
Sounds like the crank is letting go.
Old 04-21-2005, 10:51 PM
Sen Sen's Avatar
Thats what one of my friends said aswell. I'm going to the shop tommorow. I just hope it doesn't kill my wallet to get this fixed.
thanks for the advice BLT.
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Old 04-21-2005, 10:54 PM
BlazerLT's Avatar
AF -Advisor
You will practically have to rebuild it.
I would have a look at the local boneyard for a cheaper replacement.
Old 04-21-2005, 11:32 PM
blazes9395's Avatar
Newbie mod
What makes you think its the crank? He stated the truck was working fine until now.
