Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-21-2005, 03:14 PM
barrbarr31u barrbarr31u is offline
Unhappy bad headlights?
I've noticed lateley that when I drive at night, my headlights will go out. I usually switch them off and on, and they will come back on, but this does'nt last. They will flicker. Could this be a bad fuse?
Old 04-21-2005, 05:59 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: bad headlights?
sounds like a bad connection..
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 04-21-2005, 10:15 PM
gvc132 gvc132 is offline
Re: bad headlights?
Check your fuse first, usualy for me i head strait to the fuse box when something dosnt work.... just my rule of thumb... If you have a spare one replace it then even if its good. The clips on the back of the lights may have come loose aswell, however if theres one thing ive noticed in both my 91 3.8 and my 92 5.0 the electrical systems can be tempermental.
Old 04-22-2005, 04:23 PM
jiloasis74 jiloasis74 is offline
Go run it over to Ford I had the exact same problem. Someone here told me about a Ford Recall with bad headlight switch. So I took it in they ran my VIN number and it qualified. They just fixed it yesterday (4/21/05) for FREE! I'd gone to some other mechanic and he quoted me $250.00 bucks to fix the problem. Now it works perfectly and the lights are even brighter.......now I just have to fix all the other stuff wrong with it....
Old 04-22-2005, 11:08 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: bad headlights?
Don't think that the recall affected '94s but it never hurts to check.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
